Conditional eddies in isotropic turbulence Code Saturne: A Finite Volume Code for the Computation of Turbulent Incompressible Flows ? Industrial ApplicationsUnsteady measurements in a separated and reattaching flow, Phys. of Fluids Int. J. on Finite J. Fluid Mech, vol.22, issue.144, pp.2065-2070, 1979. ,
A seamless hybrid RANS-LES model based on transport equations for the subgrid stresses and elliptic blending, Physics of Fluids, vol.22, issue.5, 2010. ,
DOI : 10.1063/1.3415254
Stochastic estimation of a separated-flow field using wall-pressure-array measurements, Phys. of Fluids, pp.19-21, 2007. ,
Educing the source mechanism associated with dowstream radiation in subsonic jets, JFM, vol.170, pp.606-640, 2012. ,
Structure of a turbulent separation bubbleStructure of large scale vortices and unsteady reverse flow in the reattaching zone of a turbulent separation bubble, J. Fluid Mech. Kiya, M. and Sasaki K. J. Fluid Mech, vol.137, issue.154, pp.83-113, 1983. ,
Direct Correlation of Noise and Flow of a Jet, The Journal of the Acoustical Society of America, vol.52, issue.5A, pp.1280-90, 1972. ,
DOI : 10.1121/1.1913245
The inner???outer layer interface in large-eddy simulations with wall-layer models, International Journal of Heat and Fluid Flow, vol.24, issue.4, pp.538-550, 2003. ,
DOI : 10.1016/S0142-727X(03)00048-1
A hybrid RANS-LES approach with delayed-DES and wall-modelled LES capabilities, International Journal of Heat and Fluid Flow, vol.29, issue.6, pp.1638-1649, 2008. ,
DOI : 10.1016/j.ijheatfluidflow.2008.07.001
Wall pressure and conditional flow structures downstream of a reattaching flow region, Theor. and Comp. Fluids Dyn, pp.119-129, 2006. ,
DOI : 10.1016/j.ijheatfluidflow.2012.04.005
Physical and numerical upgrades in the detachededdy simulation of complex turbulent flows, Etude des corrélations pression Proc. 412th Euromech Coll. LES an Complex Transitional and Turbulent Flows, 2000. ,
