The Protein Data Bank, Acta Crystallographica Section D Biological Crystallography, vol.58, issue.6, pp.235-242, 2000. ,
DOI : 10.1107/S0907444902003451
PDBsum: a web-based database of summaries and analyses of all PDB structures, Trends in Biochemical Sciences, vol.22, issue.12, pp.488-490, 1997. ,
DOI : 10.1016/S0968-0004(97)01140-7
Cn3D: a new generation of three-dimensional molecular structure viewer, Trends in Biochemical Sciences, vol.22, issue.8, pp.314-316, 1997. ,
DOI : 10.1016/S0968-0004(97)01093-1
Sequence To and withIN graphics PDB Viewer (STING-PDB viewer), PDB Quart. News, vol.6, 1998. ,
Database of homology-derived protein structures and the structural meaning of sequence alignment, Proteins: Structure, Function, and Genetics, vol.4, issue.1, pp.56-68, 1991. ,
DOI : 10.1002/prot.340090107
The HSSP database of protein structure-sequence alignments, Nucleic Acids Research, vol.25, issue.1, pp.226-230, 1997. ,
DOI : 10.1093/nar/25.1.226
The HSSP database of protein structure-sequence alignments, Nucleic Acids Research, vol.24, issue.1, pp.201-205, 1996. ,
DOI : 10.1093/nar/24.1.201
A generalized profile syntax for biomolecular sequences motifs and its function in automatic sequence interpretation, ISMB-94; Proceedings 2nd International Conference on Intelligent Systems for Molecular Biology. AAAIPress, Menlo Park, pp.53-61, 1994. ,
Protein folding and association: Insights from the interfacial and thermodynamic properties of hydrocarbons, Proteins: Structure, Function, and Genetics, vol.39, issue.4, pp.281-296, 1991. ,
DOI : 10.1002/prot.340110407
Novel computer program for fast exact calculation of accessible and molecular surface areas and average surface curvature, Journal of Computational Chemistry, vol.14, issue.6, pp.600-609, 2002. ,
DOI : 10.1002/jcc.10061
A new vertex algorithm to calculate solvent accessible surface areas, Biophys. J, pp.61-174, 1992. ,
Dictionary of protein secondary structure: Pattern recognition of hydrogen-bonded and geometrical features, Biopolymers, vol.33, issue.12, pp.2577-2637, 1983. ,
DOI : 10.1002/bip.360221211
Knowledge-based protein secondary structure assignment, Proteins: Structure, Function, and Genetics, vol.206, issue.4, pp.566-679, 1995. ,
DOI : 10.1002/prot.340230412
Comparing the polarities of the amino acids: side-chain distribution coefficients between the vapor phase, cyclohexane, 1-octanol, and neutral aqueous solution, Biochemistry, vol.27, issue.5, pp.1664-1670, 1988. ,
DOI : 10.1021/bi00405a042
ScanProsite: a reference implementation of a PROSITE scanning tool, Appl. Bioinf, vol.1, pp.107-108, 2002. ,
HTTP: The Definitive Guide. O'Reilly and Associates, 2002. ,
Java Script: The Definitive Guide. O'Reilly and Associates, 1998. ,
The Java Tutorial?Object Oriented Programming for the Internet, 1996. ,
SEAVIEW and PHYLO_WIN: two graphic tools for sequence alignment and molecular phylogeny, Bioinformatics, vol.12, issue.6, pp.543-548, 1996. ,
DOI : 10.1093/bioinformatics/12.6.543
URL : https://hal.archives-ouvertes.fr/hal-00435028
TREEVIEW: An application to display phylogenetic trees on personal computers, Comput. Appl. Biosci, vol.12, pp.357-358, 1996. ,
Protein structure alignment by incremental combinatorial extension (CE) of the optimal path, Protein Engineering Design and Selection, vol.11, issue.9, pp.739-747, 1998. ,
DOI : 10.1093/protein/11.9.739
Sequence to structure alignment in comparative modeling using PrISM, Proteins: Structure, Function, and Genetics, vol.17, issue.S3, pp.66-72, 1999. ,
DOI : 10.1002/(SICI)1097-0134(1999)37:3+<66::AID-PROT10>3.0.CO;2-K
Stereochemistry of polypeptide chain configurations, Journal of Molecular Biology, vol.7, issue.1, pp.95-99, 1963. ,
DOI : 10.1016/S0022-2836(63)80023-6
CLUSTAL W: improving the sensitivity of progressive multiple sequence alignment through sequence weighting, position-specific gap penalties and weight matrix choice, Nucleic Acids Research, vol.22, issue.22, pp.4673-4680, 1994. ,
DOI : 10.1093/nar/22.22.4673
Gapped BLAST and PSI-BLAST: a new generation of protein database search programs, Nucleic Acids Research, vol.25, issue.17, pp.3389-3402, 1997. ,
DOI : 10.1093/nar/25.17.3389
Design and synthesis of germline-based hemi-humanized single-chain Fv against the CD18 surface antigen, Protein Engineering Design and Selection, vol.13, issue.5, pp.353-360, 2000. ,
DOI : 10.1093/protein/13.5.353
Analysis of structural and physico-chemical parameters involved in the specificity of binding between ??-amylases and their inhibitors, Protein Engineering Design and Selection, vol.13, issue.3, pp.167-177, 2000. ,
DOI : 10.1093/protein/13.3.167
