Lipschitz solutions of optimal control problems with state constraints of arbitrary order, Ann. Acad. Rom. Sci. Ser. Math. Appl, pp.2-3, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00465660
Well-Posedness of the Shooting Algorithm for State Constrained Optimal Control Problems with a Single Constraint and Control, SIAM Journal on Control and Optimization, vol.46, issue.4, pp.1398-1430, 2007. ,
DOI : 10.1137/06065756X
URL : https://hal.archives-ouvertes.fr/inria-00071379
Stability and sensitivity analysis for optimal control problems with a first-order state constraint and application to continuation methods, ESAIM: Control, Optimisation and Calculus of Variations, vol.14, issue.4, pp.825-863, 2008. ,
DOI : 10.1051/cocv:2008016
Revisiting the analysis of optimal control problems with several state constraints, Control Cybernet, vol.38, pp.1021-1052, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00778363
Second-order analysis for optimal control problems with pure state constraints and mixed control-state constraints, Annales de l'Institut Henri Poincare (C) Non Linear Analysis, vol.26, issue.2, pp.561-598, 2009. ,
DOI : 10.1016/j.anihpc.2007.12.002
URL : https://hal.archives-ouvertes.fr/hal-00778357
Perturbation analysis of optimization problems, Springer Series in Operations Research, 2000. ,
Applied optimal control, 1975. ,
OPTIMAL PROGRAMMING PROBLEMS WITH INEQUALITY CONSTRAINTS, AIAA Journal, vol.1, issue.11, pp.2544-2550, 1963. ,
DOI : 10.2514/3.2107
Difference Approximations in Optimal Control Problems, SIAM Journal on Control, vol.7, issue.1, pp.18-31, 1969. ,
DOI : 10.1137/0307002
Finite-Dimensional Approximations of State-Constrained Continuous Optimal Control Problems, SIAM Journal on Control, vol.10, issue.4, pp.649-670, 1972. ,
DOI : 10.1137/0310048
Discrete approximations in optimal control, In Nonsmooth analysis and geometric methods in deterministic optimal control, Math. Appl, vol.78, pp.59-80, 1993. ,
Lipschitzian Stability for State Constrained Nonlinear Optimal Control, SIAM Journal on Control and Optimization, vol.36, issue.2, pp.698-718, 1998. ,
DOI : 10.1137/S0363012996299314
The Euler approximation in state constrained optimal control, Mathematics of Computation, vol.70, issue.233, pp.173-203, 2001. ,
DOI : 10.1090/S0025-5718-00-01184-4
Lipschitz Continuity for Constrained Processes, SIAM Journal on Control and Optimization, vol.17, issue.3, pp.321-338, 1979. ,
DOI : 10.1137/0317026
Runge-Kutta methods in optimal control and the transformed adjoint system, Numerische Mathematik, vol.87, issue.2, pp.247-282, 2000. ,
DOI : 10.1007/s002110000178
Dual Approximations in Optimal Control, SIAM Journal on Control and Optimization, vol.22, issue.3, pp.423-465, 1984. ,
DOI : 10.1137/0322027
New necessary conditions of optimality for control problems with state-variable inequality constraints, Journal of Mathematical Analysis and Applications, vol.35, issue.2, pp.255-284, 1971. ,
DOI : 10.1016/0022-247X(71)90219-8
Solution point differentiability without strict complementarity in nonlinear programming, Math. Programming Stud, vol.21, pp.127-138, 1984. ,
DOI : 10.1007/BFb0121215
Sensitivity analysis for state constrained optimal control problems, Discrete Contin, Dynam. Systems, vol.4, pp.241-272, 1998. ,
On the minimum principle for optimal control problems with state constraints, Schriftenreihe des Rechenzentrum 41, 1979. ,
First and second order sufficient optimality conditions in mathematical programming and optimal control, Math. Program. Stud, vol.14, pp.163-177, 1981. ,
DOI : 10.1007/BFb0120927
First and second-order necessary and sufficient optimality conditions for infinite-dimensional programming problems, Mathematical Programming, vol.15, issue.1, pp.98-110, 1979. ,
DOI : 10.1007/BF01582096
On difference approximations of optimal control systems, J. Appl. Math. Mech, vol.42, pp.452-461, 1978. ,
First Order Conditions for General Nonlinear Optimization, SIAM Journal on Applied Mathematics, vol.30, issue.4, pp.597-607, 1976. ,
DOI : 10.1137/0130053
Strongly Regular Generalized Equations, Mathematics of Operations Research, vol.5, issue.1, pp.43-62, 1980. ,
DOI : 10.1287/moor.5.1.43
Consistent Approximations for Optimal Control Problems Based on Runge???Kutta Integration, SIAM Journal on Control and Optimization, vol.34, issue.4, pp.1235-1269, 1996. ,
DOI : 10.1137/S0363012994267352
Optimal control. systems and control: foundations and applications, 2000. ,
URL : https://hal.archives-ouvertes.fr/inria-00629428
Regularity and stability for the mathematical programming problem in Banach spaces, Applied Mathematics & Optimization, vol.13, issue.1, pp.49-62, 1979. ,
DOI : 10.1007/BF01442543
