SawjaCard: A Static Analysis Tool for Certifying Java Card Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper describes the design and implementation of a static analysis tool for certifying Java Card applications, according to security rules defined by the smart card industry. Java Card is a dialect of Java designed for programming multi-application smart cards and the tool, called SawjaCard, has been specialised for the particular Java Card programming patterns. The tool is built around a static analysis engine which uses a combination of numeric and heap analysis. It includes a model of the Java Card libraries and the Java Card firewall. The tool has been evaluated on a series of industrial applets and is shown to au-tomate a substantial part of the validation process.
sawjacard.pdf (390.63 Ko) Télécharger le fichier
hal-01093327 , version 1 (10-12-2014)
Frédéric Besson, Thomas Jensen, Pierre Vittet. SawjaCard: A Static Analysis Tool for Certifying Java Card Applications. 21st International Static Analysis Symposium (SAS 2014), 2014, Munich, Germany. pp.51 - 67, ⟨10.1007/978-3-319-10936-7_4⟩. ⟨hal-01093327⟩
500 Consultations
247 Téléchargements
