New interface
Conference papers
A Type-Based Analysis of Causality Loops in Hybrid Modelers
Albert Benveniste 1 Benoît Caillaud 1 Bruno Pagano 2 Marc Pouzet 3, 4, 5
1 HYCOMES - Modélisation hybride & conception par contrats pour les systèmes embarqués multi-physiques
Inria Rennes – Bretagne Atlantique , IRISA-D4 - LANGAGE ET GÉNIE LOGICIEL
5 Parkas - Parallélisme de Kahn Synchrone
DI-ENS - Département d'informatique - ENS Paris, Inria Paris-Rocquencourt, CNRS - Centre National de la Recherche Scientifique : UMR 8548
Abstract : Explicit hybrid systems modelers like Simulink/Stateflow allow for programming both discrete- and continuous-time behaviors with complex interactions between them. A key issue in their compilation is the static detection of algebraic or causality loops. Such loops can cause simulations to deadlock and prevent the generation of statically scheduled code.This paper addresses this issue for a hybrid modeling language that combines synchronous data-flow equations with Ordinary Differential Equations (ODEs). We introduce the operator last(x) for the left-limit of a signal x. This operator is used to break causality loops and permits a uniform treatment of discrete and continuous state variables. The semantics relies on non-standard analysis, defining an execution as a sequence of infinitesimally small steps. A signal is deemed causally correct when it can be computed sequentially and only changes infinitesimally outside of announced discrete events like zero-crossings. The causality analysis takes the form of a type system that expresses dependences between signals. In well-typed programs, signals are provably continuous during integration provided that imported external functions are also continuous.The effectiveness of this system is illustrated with several examples written in Zélus, a Lustre-like synchronous language extended with hierarchical automata and ODEs.
Complete list of metadata
https://hal.inria.fr/hal-01093388
Contributor : Timothy Bourke Connect in order to contact the contributor
Submitted on : Wednesday, December 10, 2014 - 3:46:15 PM
Last modification on : Thursday, March 17, 2022 - 10:08:44 AM
Links full text
Identifiers
Citation
Albert Benveniste, Benoît Caillaud, Bruno Pagano, Marc Pouzet. A Type-Based Analysis of Causality Loops in Hybrid Modelers. HSCC '14: International Conference on Hybrid Systems: Computation and Control, Apr 2014, Berlin, Germany. pp.13, ⟨10.1145/2562059.2562125⟩. ⟨hal-01093388⟩
Share
Metrics
Record views
594
