Maximum Contact Map Overlap Revisited, Journal of Computational Biology, vol.18, issue.1, pp.27-41, 2011. ,
DOI : 10.1089/cmb.2009.0196
URL : https://hal.archives-ouvertes.fr/inria-00536624
Accuracy analysis of multiple structure alignments, Protein Science, vol.40, issue.10, pp.2027-2035, 2009. ,
DOI : 10.1002/pro.213
Parallel Seed-Based Approach to Protein Structure Similarity Detection, Lecture Notes in Computer Science, vol.8385, issue.2, pp.278-287, 2013. ,
DOI : 10.1007/978-3-642-55195-6_26
URL : https://hal.archives-ouvertes.fr/hal-00881507
OpenMP: an industry standard API for shared-memory programming, IEEE Computational Science and Engineering, vol.5, issue.1, pp.46-55, 1998. ,
DOI : 10.1109/99.660313
Surprising similarities in structure comparison, Current Opinion in Structural Biology, vol.6, issue.3, pp.377-385, 1996. ,
DOI : 10.1016/S0959-440X(96)80058-3
Using MPI: Portable Parallel Programming with the Message Passing Interface, 1999. ,
Protein Structure Comparison by Alignment of Distance Matrices, Journal of Molecular Biology, vol.233, issue.1, pp.123-138, 1993. ,
DOI : 10.1006/jmbi.1993.1489
Searching protein structure databases has come of age, Proteins: Structure, Function, and Genetics, vol.18, issue.3, pp.165-173, 1994. ,
DOI : 10.1002/prot.340190302
A Fast and High Quality Multilevel Scheme for Partitioning Irregular Graphs, SIAM Journal on Scientific Computing, vol.20, issue.1, pp.359-392, 1998. ,
DOI : 10.1137/S1064827595287997
Protein structure similarities, Current Opinion in Structural Biology, vol.11, issue.3, pp.348-353, 2001. ,
DOI : 10.1016/S0959-440X(00)00214-1
Comprehensive Evaluation of Protein Structure Alignment Methods: Scoring by Geometric Measures, Journal of Molecular Biology, vol.346, issue.4, pp.1173-1188, 2005. ,
DOI : 10.1016/j.jmb.2004.12.032
From The Cover: Approximate protein structural alignment in polynomial time, Proceedings of the National Academy of Sciences, vol.101, issue.33, pp.12201-12206, 2004. ,
DOI : 10.1073/pnas.0404383101
ProBiS algorithm for detection of structurally similar protein binding sites by local structural alignment, Bioinformatics, vol.26, issue.9, pp.1160-1168, 2010. ,
DOI : 10.1093/bioinformatics/btq100
ProSup: a refined tool for protein structure alignment, Protein Engineering Design and Selection, vol.13, issue.11, pp.745-752, 2000. ,
DOI : 10.1093/protein/13.11.745
Anomalies in parallel branch-and-bound algorithms, Communications of the ACM, vol.27, issue.6, pp.594-602, 1984. ,
DOI : 10.1145/358080.358103
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.12.3044
The protein threading problem with sequence amino acid interaction preferences is NP-complete, "Protein Engineering, Design and Selection", vol.7, issue.9, pp.1059-1068, 1994. ,
DOI : 10.1093/protein/7.9.1059
Fast determination of the optimal rotational matrix for macromolecular superpositions, Journal of Computational Chemistry, vol.450, issue.Suppl 2, pp.311561-1563, 2010. ,
DOI : 10.1002/jcc.21439
A Mathematical Framework for Protein Structure Comparison, PLoS Computational Biology, vol.6, issue.2, p.1001075, 2011. ,
DOI : 10.1371/journal.pcbi.1001075.t002
Maximum Cliques in Protein Structure Comparison, Experimental Algorithms, pp.106-117, 2010. ,
DOI : 10.1007/978-3-642-13193-6_10
URL : https://hal.archives-ouvertes.fr/inria-00536700
GR-Align: fast and flexible alignment of protein 3D structures using graphlet degree similarity, Bioinformatics, vol.30, issue.9, 2014. ,
DOI : 10.1093/bioinformatics/btu020
MICAN : a protein structure alignment algorithm that can handle Multiple-chains, Inverse alignments, C?? only models, Alternative alignments, and Non-sequential alignments, BMC Bioinformatics, vol.14, issue.1, pp.1-22, 2013. ,
DOI : 10.1016/j.jmb.2005.12.084
Toward the detection and validation of repeats in protein structure, Proteins, vol.57, issue.2, pp.365-80, 2004. ,
Detecting Repetitions and Periodicities in Proteins by Tiling the Structural Space, The Journal of Physical Chemistry B, vol.117, issue.42, pp.12887-97, 2013. ,
DOI : 10.1021/jp402105j
FlexSnap: flexible non-sequential protein structure alignment. Algorithms for molecular biology, p.12, 2010. ,
DOI : 10.1186/1748-7188-5-12
URL : http://doi.org/10.1186/1748-7188-5-12
Finding, Counting and Listing All Triangles in Large Graphs, an Experimental Study, Experimental and Efficient Algorithms, pp.606-609, 2005. ,
DOI : 10.1007/11427186_54
A New Method to Detect Related Function Among Proteins Independent of Sequence and Fold Homology, Journal of Molecular Biology, vol.323, issue.2, pp.387-406, 2002. ,
DOI : 10.1016/S0022-2836(02)00811-2
Protein structure alignment by incremental combinatorial extension (CE) of the optimal path, Protein Engineering Design and Selection, vol.11, issue.9, pp.739-747, 1998. ,
DOI : 10.1093/protein/11.9.739
Optimal Protein Structure Alignment Using Maximum Cliques, Operations Research, vol.53, issue.3, pp.389-402, 2005. ,
DOI : 10.1287/opre.1040.0189
Structural similarity of DNA-binding domains of bacteriophage repressors and the globin core, Current Biology, vol.3, issue.3, pp.141-148, 1993. ,
DOI : 10.1016/0960-9822(93)90255-M
DALIX: Optimal DALI Protein Structure Alignment, IEEE/ACM Transactions on Computational Biology and Bioinformatics, vol.10, issue.1, pp.26-36, 2013. ,
DOI : 10.1109/TCBB.2012.143
PAUL: protein structural alignment using integer linear programming and Lagrangian relaxation, BMC Bioinformatics, vol.10, issue.Suppl 13, p.2, 2009. ,
DOI : 10.1186/1471-2105-10-S13-P2
URL : http://doi.org/10.1186/1471-2105-10-s13-p2
LGA: a method for finding 3D similarities in protein structures, Nucleic Acids Research, vol.31, issue.13, pp.3370-3374, 2003. ,
DOI : 10.1093/nar/gkg571
TM-align: a protein structure alignment algorithm based on the TM-score, Nucleic Acids Research, vol.33, issue.7, pp.2302-2309, 2005. ,
DOI : 10.1093/nar/gki524
Scoring function for automated assessment of protein structure template quality, Proteins: Structure, Function, and Bioinformatics, vol.101, issue.4, pp.702-710, 2004. ,
DOI : 10.1002/prot.20264
