Adding a single state memory optimally accelerates symmetric linear maps - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Automatic Control Année : 2016
Alain Sarlette
  • Fonction : Auteur
  • PersonId : 10453
  • IdHAL : asarlet
Previous papers have proposed to add memory registers to the dynamics of discrete-time linear systems in order to accelerate their convergence. In particular, it has been proved that adding one memory slot per agent allows faster convergence towards average consensus. We here prove that this situation cannot be improved by adding more memory slots, when the knowledge about the self-adjoint linear map to be accelerated reduces to bounds on its extreme eigenvalues.
All2-arxiv.pdf (759.01 Ko) Télécharger le fichier
hal-01093907 , version 1 (05-01-2015)
hal-01093907 , version 2 (28-12-2015)
Alain Sarlette. Adding a single state memory optimally accelerates symmetric linear maps. IEEE Transactions on Automatic Control, 2016, 61 (11), pp.3533. ⟨10.1109/TAC.2016.2516247⟩. ⟨hal-01093907v2⟩
210 Consultations
338 Téléchargements
