Problems in decentralized decision making and computation, 1984. ,
First- and Second-Order Diffusive Methods for Rapid, Coarse, Distributed Load Balancing, Theory of Computing Systems, vol.31, issue.4, pp.331-354, 1998. ,
DOI : 10.1007/s002240000092
Faster Linear Iterations for Distributed Averaging, Proceedings of the 17th IFAC World Congress, pp.2861-2866, 2008. ,
DOI : 10.3182/20080706-5-KR-1001.00482
Accelerated gradient methods for networked optimization, Proceedings of the 2011 American Control Conference, 1211. ,
DOI : 10.1109/ACC.2011.5990992
Analysis of accelerated gossip algorithms, Automatica, vol.49, issue.4, pp.873-883, 2013. ,
DOI : 10.1016/j.automatica.2013.01.001
A method of solving a convex programming problem with convergence rate, Soviet Mathematics Doklady, pp.372-376, 1983. ,
Some discrete-time counterparts to Kharitonov's stability criterion for uncertain systems, IEEE Transactions on Automatic Control, vol.31, issue.4, pp.355-356, 1986. ,
DOI : 10.1109/TAC.1986.1104268
A generalization of Kharitonov's four-polynomial concept for robust stability problems with linearly dependent coefficient perturbations, IEEE Transactions on Automatic Control, vol.34, issue.2, pp.157-165, 1989. ,
DOI : 10.1109/9.21087
Linear time average consensus on fixed graphs and implications for decentralized optimization and multi-agent control, 2015. ,
Chebyshev Polynomials in Distributed Consensus Applications, IEEE Transactions on Signal Processing, vol.61, issue.3, pp.693-706, 2013. ,
DOI : 10.1109/TSP.2012.2226173
Polynomial Filtering for Fast Convergence in Distributed Consensus, IEEE Transactions on Signal Processing, vol.57, issue.1, 2008. ,
DOI : 10.1109/TSP.2008.2006147
Finite-time distributed consensus in graphs with timeinvariant topologies, Proc. American Control Conference, pp.711-716, 2007. ,
Graph diameter, eigenvalues, and minimum-time consensus, Automatica, vol.50, issue.2, pp.635-640, 2014. ,
DOI : 10.1016/j.automatica.2013.11.034
Definitive consensus for distributed data inference, 2011. ,
Lifting Markov chains to speed up mixing, Proceedings of the thirty-first annual ACM symposium on Theory of computing , STOC '99, 1999. ,
DOI : 10.1145/301250.301315
Distributed averaging via lifted markov chains Information Theory, IEEE Transactions on, vol.56, issue.1, pp.634-647, 2010. ,
Mistuning-Based Control Design to Improve Closed-Loop Stability Margin of Vehicular Platoons, IEEE Transactions on Automatic Control, vol.54, issue.9, pp.2100-2113, 2009. ,
DOI : 10.1109/TAC.2009.2026934
