Problems in decentralized decision making and computation, 1984. ,
Fastest Mixing Markov Chain on a Graph, SIAM Review, vol.46, issue.4, pp.667-689, 2004. ,
DOI : 10.1137/S0036144503423264
Lifting Markov chains to speed up mixing, Proceedings of the thirty-first annual ACM symposium on Theory of computing , STOC '99, pp.275-281, 1999. ,
DOI : 10.1145/301250.301315
Distributed asynchronous deterministic and stochastic gradient optimization algorithms, IEEE Transactions on Automatic Control, vol.31, issue.9, pp.803-812, 1986. ,
DOI : 10.1109/TAC.1986.1104412
Kalman Filtering in Wireless Sensor Networks, IEEE Control Systems Magazine, vol.30, issue.2, pp.66-86, 2010. ,
DOI : 10.1109/MCS.2009.935569
Approximate distributed kalman filtering in sensor networks with quantifiable performance, IPSN 2005. Fourth International Symposium on Information Processing in Sensor Networks, 2005., p.18, 2005. ,
DOI : 10.1109/IPSN.2005.1440912
Distributed Kalman filtering based on consensus strategies, Selected Areas in Communications, pp.622-633, 2008. ,
DOI : 10.1109/JSAC.2008.080505
A survey of consensus problems in multi-agent coordination, American Control Conference Proceedings of the 2005, pp.1859-1864, 2005. ,
Convergence in Multiagent Coordination, Consensus, and Flocking, Proceedings of the 44th IEEE Conference on Decision and Control, p.2996, 1998. ,
DOI : 10.1109/CDC.2005.1582620
Consensus and Cooperation in Networked Multi-Agent Systems, Proceedings of the IEEE, vol.95, issue.1, pp.215-233, 2007. ,
DOI : 10.1109/JPROC.2006.887293
Fast linear iterations for distributed averaging, Systems & Control Letters, vol.53, issue.1, pp.65-78, 2004. ,
DOI : 10.1016/j.sysconle.2004.02.022
First- and Second-Order Diffusive Methods for Rapid, Coarse, Distributed Load Balancing, Theory of Computing Systems, vol.31, issue.4, pp.331-354, 1998. ,
DOI : 10.1007/s002240000092
Chebyshev Polynomials in Distributed Consensus Applications, IEEE Transactions on Signal Processing, vol.61, issue.3, pp.693-706, 2013. ,
DOI : 10.1109/TSP.2012.2226173
Graph diameter, eigenvalues, and minimum-time consensus, Automatica, vol.50, issue.2, pp.635-640, 2014. ,
DOI : 10.1016/j.automatica.2013.11.034
Spectral graph theory and the inverse eigenvalue problem of a graph, Electronic Journal of Linear Algebra, vol.14, issue.1, p.3, 2005. ,
DOI : 10.13001/1081-3810.1174
Linear time average consensus on fixed graphs and implications for decentralized optimization and multi-agent control ArXiv e-prints, 2014. ,
Accelerated gossip algorithms for distributed computation, Proc. of the 44th Annual Allerton Conference on Communication, Control, and Computation. Citeseer, pp.952-959, 2006. ,
Adding a single memory per agent gives the fastest average consensus, IEEE Trans. Automatic Control, 2014. ,
Analysis of a nonreversible Markov chain sampler, The Annals of Applied Probability, vol.10, issue.3, pp.726-752, 2000. ,
DOI : 10.1214/aoap/1019487508
Finite-Time Consensus Using Stochastic Matrices With Positive Diagonals, IEEE Transactions on Automatic Control, vol.60, issue.4, pp.1070-1073, 2015. ,
DOI : 10.1109/TAC.2014.2352691
Finite-time average consensus based protocol for distributed estimation over AWGN channels, IEEE Conference on Decision and Control and European Control Conference, pp.5595-5600, 2011. ,
DOI : 10.1109/CDC.2011.6160868
Revisiting Finite-Time Distributed Algorithms via Successive Nulling of Eigenvalues, IEEE Signal Processing Letters, vol.22, issue.1, pp.54-57, 2015. ,
DOI : 10.1109/LSP.2014.2346657
On matrix factorization and finite-time averageconsensus, 28th Chinese Control Conference Proceedings of the 48th IEEE Conference, pp.5798-5803, 2009. ,
Finite-time distributed consensus through graph filters, 2014 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.1080-1084, 2014. ,
DOI : 10.1109/ICASSP.2014.6853763
Finite-Time Distributed Consensus in Graphs with Time-Invariant Topologies, 2007 American Control Conference, pp.711-716, 2007. ,
DOI : 10.1109/ACC.2007.4282726
Accelerating Distributed Consensus Using Extrapolation, IEEE Signal Processing Letters, vol.14, issue.10, pp.665-668, 2007. ,
DOI : 10.1109/LSP.2007.896383
Spectra of graphs, 2011. ,
DOI : 10.1007/978-1-4614-1939-6
Fastest Mixing Markov Chain on Graphs with Symmetries, SIAM Journal on Optimization, vol.20, issue.2, pp.792-819, 2009. ,
DOI : 10.1137/070689413
Pole assignment for linear time-invariant systems by periodic memoryless output feedback, Automatica, vol.28, issue.6, pp.1159-1168, 1992. ,
DOI : 10.1016/0005-1098(92)90057-M
Quantum random walks, Physical Review A, vol.48, issue.2, p.1687, 1993. ,
DOI : 10.1103/PhysRevA.48.1687
