Machine Learning for Neuroimaging with Scikit-Learn - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Frontiers in Neuroscience Année : 2013
Statistical machine learning methods are increasingly used for neuroimaging data analysis. Their main virtue is their ability to model high-dimensional datasets, e.g. multivariate analysis of activation images or resting-state time series. Supervised learning is typically used in decoding or encoding settings to relate brain images to behavioral or clinical observations, while unsupervised learning can uncover hidden structures in sets of images (e.g. resting state functional MRI) or find sub-populations in large cohorts. By considering different functional neuroimaging applications, we illustrate how scikit-learn, a Python machine learning library, can be used to perform some key analysis steps. Scikit-learn contains a very large set of statistical learning algorithms, both supervised and unsupervised, and its application to neuroimaging data provides a versatile tool to study the brain.
frontiers.pdf (5.67 Mo) Télécharger le fichier
hal-01093971 , version 1 (11-12-2014)
Alexandre Abraham, Fabian Pedregosa, Michael Eickenberg, Philippe Gervais, Andreas Muller, et al.. Machine Learning for Neuroimaging with Scikit-Learn. Frontiers in Neuroscience, 2013, pp.15. ⟨10.3389/fninf.2014.00014⟩. ⟨hal-01093971⟩
616 Consultations
1617 Téléchargements
