The M4RI Library ? Version, 2009. ,
How Far Can We Go Beyond Linear Cryptanalysis?, LNCS, vol.3329, pp.432-450, 2004. ,
DOI : 10.1007/978-3-540-30539-2_31
Decoding Random Binary Linear Codes in 2 n/20: How 1???+???1???=???0 Improves Information Set Decoding, EUROCRYPT 2012, pp.520-536, 2012. ,
DOI : 10.1007/978-3-642-29011-4_31
Masking and leakage-resilient primitives: One, the other(s) or both? Cryptology ePrint Archive, 2014. ,
Faster binary-field multiplication and faster binary-field macs, SAC, Lecture Notes in Computer Science, 2014. ,
Magma Package: Hybrid Approach for Solving Multivariate Polynomial Systems over Finite Fields ,
DOI : 10.1515/jmc.2009.009
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.188.504
Noise-tolerant learning, the parity problem, and the statistical query model, Journal of the ACM, vol.50, issue.4, pp.506-519, 2003. ,
DOI : 10.1145/792538.792543
Towards Sound Approaches to Counteract Power-Analysis Attacks, CRYPTO'99, pp.398-412, 1999. ,
DOI : 10.1007/3-540-48405-1_26
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.94.8951
Higher Order Masking of Look-Up Tables, EUROCRYPT 2014, pp.441-458, 2014. ,
DOI : 10.1007/978-3-642-55220-5_25
Information theory, 1991. ,
URL : https://hal.archives-ouvertes.fr/hal-00756546
François-Xavier Standaert, Lo¨?cLo¨?c van Oldeneel tot Oldenzeel, and Nicolas Veyrat-Charvillon. Efficient Removal of Random Delays from Embedded Software Implementations Using Hidden Markov Models ,
Efficient selection of time samples for higherorder DPA with projection pursuits, IACR Cryptology ePrint Archive, p.412, 2014. ,
A new efficient algorithm for computing Gröbner bases without reduction to zero F5, International Symposium on Symbolic and Algebraic Computation Symposium -ISSAC, 2002. 14. Niels Ferguson. Authentication weaknesses in GCM, 2005. ,
Efficient Masked S-Boxes Processing ??? A Step Forward ???, LNCS, vol.14, issue.8469, pp.251-266, 2014. ,
DOI : 10.1007/978-3-319-06734-6_16
Key-Recovery Attacks on Universal Hash Function Based MAC Algorithms, LNCS, vol.5157, pp.144-161, 2008. ,
DOI : 10.1007/978-3-540-85174-5_9
A First-Order DPA Attack Against AES in Counter Mode with Unknown Initial Counter, CHES 2007, pp.1-13, 2007. ,
DOI : 10.1007/978-3-540-74735-2_1
Authentication Failures in NIST version of GCM, 2006. ,
Evaluation of DPA Characteristics of SASEBO for Board Level Simulation, 2010. ,
Improved generalized birthday attack Cryptology ePrint Archive http://eprint.iacr.org/2011/377. 21. ´ Eric Levieil and Pierre-Alain Fouque. An improved LPN algorithm, LNCS, vol.377, issue.4116, pp.348-359, 2006. ,
The Parity Problem in the Presence of Noise, Decoding Random Linear Codes, and the Subset Sum Problem, APPROX-RANDOM, pp.378-389, 2005. ,
DOI : 10.1007/11538462_32
Hardware Countermeasures against DPA ??? A Statistical Analysis of Their Effectiveness, CT-RSA 2004, pp.222-235, 2004. ,
DOI : 10.1007/978-3-540-24660-2_18
Power analysis attacks revealing the secrets of smart cards, 2007. ,
The Galois/Counter Mode of Operation (GCM), 2005. ,
Fresh Re-keying: Security against Side-Channel and Fault Attacks for Low-Cost Devices, LNCS, vol.10, issue.6055, pp.279-296, 2010. ,
DOI : 10.1007/978-3-642-12678-9_17
Physically observable cryptography (extended abstract), LNCS, vol.2951, pp.278-296, 2004. ,
DOI : 10.1007/978-3-540-24638-1_16
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.14.6299
On weak keys and forgery attacks against polynomial-based MAC schemes, LNCS, vol.2013, issue.8424, pp.287-304, 2013. ,
Provably Secure Higher-Order Masking of AES, CHES 2010, pp.413-427, 2010. ,
DOI : 10.1007/978-3-642-15031-9_28
Cycling Attacks on GCM, GHASH and Other Polynomial MACs and Hashes, LNCS, vol.2012, issue.7549, pp.216-225, 2012. ,
DOI : 10.1007/978-3-642-34047-5_13
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.400.5845
An optimal key enumeration algorithm and its application to sidechannel attacks, SAC 2012, pp.390-406, 2012. ,
Security Evaluations beyond Computing Power, EUROCRYPT 2013, pp.126-141, 2013. ,
DOI : 10.1007/978-3-642-38348-9_8
URL : http://hdl.handle.net/2078.1/133720
A high speed architecture for galois/counter mode of operation (GCM) Cryptology ePrint Archive, Report, vol.146146, 2005. ,
