RELIC is an Efficient LIbrary for Cryptography ,
Sorting networks and their applications, Proceedings of the April 30--May 2, 1968, spring joint computer conference on, AFIPS '68 (Spring), pp.307-314, 1968. ,
DOI : 10.1145/1468075.1468121
On the generation of one-time keys in DL signature schemes. Presentation at IEEE P1363 Working Group meeting, 2000. ,
Noise-tolerant learning, the parity problem, and the statistical query model, Journal of the ACM, vol.50, issue.4, pp.506-519, 2003. ,
DOI : 10.1145/792538.792543
High-Performance Scalar Multiplication Using 8-Dimensional GLV/GLS Decomposition ,
DOI : 10.1007/978-3-642-40349-1_19
Cache-Timing Template Attacks, Lecture Notes in Computer Science, vol.5912, pp.667-684, 2009. ,
DOI : 10.1007/978-3-642-10366-7_39
On Modular Decomposition of Integers, Lecture Notes in Computer Science, vol.1, issue.1, pp.386-402, 2009. ,
DOI : 10.1515/JMC.2007.001
Standards for efficient cryptography, SEC 1: Elliptic curve cryptography, 2000. ,
BKZ 2.0: Better Lattice Security Estimates, Lecture Notes in Computer Science, vol.7073, pp.1-20, 2011. ,
DOI : 10.1007/978-3-642-25385-0_1
URL : https://hal.archives-ouvertes.fr/hal-01109961
Faster Compact Diffie???Hellman: Endomorphisms on the x-line, EUROCRYPT, pp.183-200, 2014. ,
DOI : 10.1007/978-3-642-55220-5_11
URL : https://hal.archives-ouvertes.fr/hal-00932952
The Design and Implementation of FFTW3, Proceedings of the IEEE, vol.93, issue.2, pp.216-231, 2005. ,
DOI : 10.1109/JPROC.2004.840301
Endomorphisms for Faster Elliptic Curve Cryptography on a Large Class of Curves, J. Cryptology, vol.47, issue.3, pp.446-469, 2011. ,
DOI : 10.1007/3-540-48892-8_15
Efficient multiplication on curves having an endomorphism of norm 1. Workshop on Elliptic Curve Cryptography, 1999. ,
Faster Point Multiplication on Elliptic Curves with Efficient Endomorphisms, Lecture Notes in Computer Science, vol.2139, pp.190-200, 2001. ,
DOI : 10.1007/3-540-44647-8_11
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.32.2004
Four-Dimensional GLV via the Weil Restriction, Lecture Notes in Computer Science, vol.8269, issue.1, pp.79-96, 2013. ,
DOI : 10.1007/978-3-642-42033-7_5
URL : https://hal.archives-ouvertes.fr/hal-00864966
An Improved LPN Algorithm, Lattice Attacks on Digital Signature Schemes. Des. Codes Cryptography Lecture Notes in Computer Science, vol.23, issue.4116, pp.283-290, 2001. ,
Solving BDD by Enumeration: An Update, Lecture Notes in Computer Science, vol.7779, pp.293-309, 2013. ,
DOI : 10.1007/978-3-642-36095-4_19
URL : https://hal.archives-ouvertes.fr/hal-00864361
Elliptic curves: function theory, geometry, arithmetic, 1999. ,
DOI : 10.1017/CBO9781139174879
Using Bleichenbacher???s solution to the hidden number problem to attack nonce leaks in 384-bit ECDSA: extended version, Journal of Cryptographic Engineering, vol.35, issue.2, pp.33-45, 2014. ,
DOI : 10.1007/s13389-014-0072-z
Experimenting with Faults, Lattices and the DSA, Lecture Notes in Computer Science, vol.3386, pp.16-28, 2005. ,
DOI : 10.1007/978-3-540-30580-4_3
The Insecurity of the Digital Signature Algorithm with Partially Known Nonces, Journal of Cryptology, vol.15, issue.3, pp.151-176, 2002. ,
DOI : 10.1007/s00145-002-0021-3
The Insecurity of the Elliptic Curve Digital Signature Algorithm with Partially Known Nonces, Designs, Codes and Cryptography, vol.30, issue.2, pp.201-217, 2003. ,
DOI : 10.1023/A:1025436905711
Low-Dimensional Lattice Basis Reduction Revisited, Lecture Notes in Computer Science, vol.3076, pp.338-357, 2004. ,
DOI : 10.1007/978-3-540-24847-7_26
URL : https://hal.archives-ouvertes.fr/inria-00328629
Lattice-Based Fault Attacks on Signatures, Fault Analysis in Cryptography, Information Security and Cryptography, pp.201-220, 2012. ,
DOI : 10.1007/978-3-642-29656-7_12
URL : https://hal.archives-ouvertes.fr/hal-00922233
Two is the fastest prime: lambda coordinates for binary elliptic curves, Journal of Cryptographic Engineering, vol.1, issue.4, pp.3-17, 2014. ,
DOI : 10.1007/s13389-013-0069-z
An Alternate Decomposition of an Integer for Faster Point Multiplication on Certain Elliptic Curves, Lecture Notes in Computer Science, vol.2274, pp.323-334, 2002. ,
DOI : 10.1007/3-540-45664-3_23
Kangaroos, Monopoly and Discrete Logarithms, Journal of Cryptology, vol.13, issue.4, pp.437-447, 2000. ,
DOI : 10.1007/s001450010010
Families of Fast Elliptic Curves from ???-curves, Lecture Notes in Computer Science, vol.8269, issue.1, pp.61-78, 2013. ,
DOI : 10.1007/978-3-642-42033-7_4
URL : https://hal.archives-ouvertes.fr/hal-00825287
An 8-bit AVR-Based Elliptic Curve Cryptographic RISC Processor for the Internet of Things, 2012 45th Annual IEEE/ACM International Symposium on Microarchitecture Workshops, pp.39-46, 2012. ,
DOI : 10.1109/MICROW.2012.20
