New interface
Journal articles
Performance evaluation of hierarchical TTL-based cache networks
Abstract : There has been considerable research on the performance analysis of on-demand caching replacement policies like Least-Recently-Used (LRU), First-In-First-Out (FIFO) or Random (RND). Much progress has been made on the analysis of a single cache running these algorithms. However it has been almost impossible to extend the results to networks of caches. In this paper, we introduce a Time-To-Live (TTL) based caching model, that assigns a timer to each content stored in the cache and redraws it every time the content is requested (at each hit/miss). We derive the performance metrics (hit/miss ratio and rate, occupancy) of a TTL-based cache in isolation fed by stationary and ergodic request processes with general TTL distributions. Moreover we propose an iterative procedure to analyze TTL-based cache networks under the assumptions that requests are described by {\em renewal processes} (that generalize Poisson processes or the standard IRM assumption). We validate our theoretical findings through event-driven and Monte-Carlo simulations based on the Fourier Amplitude Sensitivity Test to explore the space of the input parameters. We observe that our analytic model predicts remarkably well all metrics of interest with relative errors smaller than 1%.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-01094694
Contributor : Giovanni Neglia Connect in order to contact the contributor
Submitted on : Friday, December 12, 2014 - 5:38:15 PM
Last modification on : Friday, November 18, 2022 - 9:25:35 AM
Long-term archiving on: : Friday, March 13, 2015 - 11:26:13 AM
File
Comnet_submission_2013_final_v...
Identifiers
Collections
Citation
Nicaise Choungmo Fofack, Philippe Nain, Giovanni Neglia, Don Towsley. Performance evaluation of hierarchical TTL-based cache networks. Computer Networks, 2014, 65, pp.212-231. ⟨10.1016/j.comnet.2014.03.006⟩. ⟨hal-01094694⟩
Share
Metrics
Record views
198
Files downloads
281
