Profiling the Memory Usage of OCaml Applications without Changing its Behavior - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Çagdas Bozman
Michel Mauny
Fabrice Le Fessant
Thomas Gazagnaire
  • Fonction : Auteur
  • PersonId : 962419
In this paper, we present the current state of our work on profiling the memory usage of OCaml programs. Our technique allows to observe track types, allocation points and reachability paths of blocks, with no runtime cost, except for saving the observations.
profiling-memory.pdf (154.68 Ko) Télécharger le fichier
hal-01095305 , version 1 (15-12-2014)
  • HAL Id : hal-01095305 , version 1
Çagdas Bozman, Michel Mauny, Fabrice Le Fessant, Thomas Gazagnaire. Profiling the Memory Usage of OCaml Applications without Changing its Behavior. OCaml Users and Developers Workshop (OCaml), Sep 2013, boston, United States. ⟨hal-01095305⟩
104 Consultations
98 Téléchargements
