New interface
Preprints, Working Papers, ...
Gradient waveform design for variable density sampling in Magnetic Resonance Imaging
Abstract : Fast coverage of k-space is a major concern to speed up data acquisition in Magnetic Resonance Imaging (MRI) and limit image distortions due to long echo train durations. The hardware gradient constraints (magnitude, slew rate) must be taken into account to collect a sufficient amount of samples in a minimal amount of time. However, sampling strategies (e.g., Compressed Sensing) and optimal gradient waveform design have been developed separately so far. The major flaw of existing methods is that they do not take the sampling density into account, the latter being central in sampling theory. In particular, methods using optimal control tend to agglutinate samples in high curvature areas. In this paper, we develop an iterative algorithm to project any parameterization of k-space trajectories onto the set of feasible curves that fulfills the gradient constraints. We show that our projection algorithm provides a more efficient alternative than existinf approaches and that it can be a way of reducing acquisition time while maintaining sampling density for piece-wise linear trajectories.
Complete list of metadata
Cited literature [32 references]  Display  Hide  Download
https://hal.inria.fr/hal-01095320
Contributor : Nicolas Chauffert Connect in order to contact the contributor
Submitted on : Tuesday, December 30, 2014 - 11:27:43 AM
Last modification on : Wednesday, November 23, 2022 - 11:54:27 AM
Long-term archiving on: : Saturday, April 15, 2017 - 12:00:20 PM
curve_projectionv5.pdf
Identifiers
  • HAL Id : hal-01095320, version 2
  • ARXIV : 1412.4621
Citation
Nicolas Chauffert, Pierre Weiss, Jonas Kahn, Philippe Ciuciu. Gradient waveform design for variable density sampling in Magnetic Resonance Imaging. {date}. ⟨hal-01095320v2⟩
Share
Metrics
Record views
772
Files downloads
517
