Inside Case-Based Reasoning, 1989. ,
Abstract, The Journal of Symbolic Logic, vol.48, issue.02, pp.510-530, 1985. ,
DOI : 10.1080/00048408412341331
An Investigation of Generalized Cases, Proceedings of the 5th International Conference on Case Base Reasoning (ICCBR'03). Volume 2689 of LNAI, pp.261-275, 2003. ,
DOI : 10.1007/3-540-45006-8_22
Learning by analogy: Formulating and generalizing plans from past experience, Machine Learning, An Artificial Intelligence Approach, pp.137-161, 1983. ,
Derivational analogy: A Theory of Reconstructive Problem Solving and Expertise Acquisition, Machine Learning, pp.371-392, 1986. ,
Propositional knowledge base revision and minimal change, Artificial Intelligence, vol.52, issue.3, pp.263-294, 1991. ,
DOI : 10.1016/0004-3702(91)90069-V
Investigations into a theory of knowledge base revision: Preliminary report, In: AAAI, pp.475-479, 1988. ,
DA2 merging operators, Artificial Intelligence, vol.157, issue.1-2, pp.49-79, 2004. ,
DOI : 10.1016/j.artint.2004.04.008
Application of the Revision Theory to Adaptation in Case-Based Reasoning: The Conservative Adaptation, Proceedings of the 7th International Conference on Case-Based Reasoning (ICCBR-07). Lecture Notes in Artificial Intelligence 4626, pp.239-253, 2007. ,
DOI : 10.1007/978-3-540-74141-1_17
URL : https://hal.archives-ouvertes.fr/inria-00189626
Case-Based Reasoning, 1993. ,
A new polynomial-time algorithm for linear programming, Combinatorica, vol.244, issue.S, pp.373-396, 1984. ,
DOI : 10.1007/BF02579150
Belief Merging-Based Case Combination, pp.105-119, 2009. ,
DOI : 10.1007/3-540-60598-3_9
URL : https://hal.archives-ouvertes.fr/inria-00421724
Adaptation of ingredient quantities and of textual preparations, 18h International Conference on Case-Based Reasoning -ICCBR 2010Computer Cooking Contest" Workshop Proceedings, 2010. ,
Correct and Complete Retrieval for Case-Based Problem-Solving ,
Learning adaptation knowledge to improve case-based reasoning, Artificial Intelligence, vol.170, issue.16-17, pp.16-17, 2006. ,
DOI : 10.1016/j.artint.2006.09.001
Case Base Mining for Adaptation Knowledge Acquisition, Proceedings of the 20th International Joint Conference on Artificial Intelligence (IJCAI'07), pp.750-755, 2007. ,
URL : https://hal.archives-ouvertes.fr/inria-00127347
Using Case-Base Data to Learn Adaptation Knowledge for Design, Proceedings of the 17th International Joint Conference on Artificial Intelligence (IJCAI'01), pp.1011-1016, 2001. ,
Acquiring Case Adaptation Knowledge: A Hybrid Approach, In: AAAI/IAAI, vol.1, pp.684-689, 1996. ,
Applying Recursive CBR for the Customization of Structure Products in an Electronic Shop, Advances in Case-Based Reasoning ? Proceedings of the fifth European Workshop on Case-Based Reasoning (EWCBR- 2k). Lecture Notes in Artificial Intelligence 1898, pp.297-308, 2000. ,
The Description Logic Handbook, 2003. ,
DOI : 10.1017/CBO9780511711787
On Applying the AGM Theory to DLs and OWL, Proceedings of the 4th International Semantic Web Conference (ISWC 2005), pp.216-231, 2005. ,
DOI : 10.1007/11574620_18
Debugging unsatisfiable classes in OWL ontologies, Web Semantics: Science, Services and Agents on the World Wide Web, pp.268-293, 2005. ,
DOI : 10.1016/j.websem.2005.09.005
An Algorithm for Adapting Cases Represented in ALC, 22th Internationational Joint Conference on Artificial Intelligence, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00584103
An interval-based representation of temporal knowledge, Proceedings 7th International Joint Conference on Artificial Intelligence, pp.221-226, 1981. ,
A spatial logic based on regions and connection, In: Knowledge Representation, pp.165-176, 1992. ,
A Syntactical Approach to Qualitative Constraint Networks Merging, Proc. of the 17th LPAR (Logic for Programming, pp.233-247, 2010. ,
DOI : 10.1007/978-3-642-16242-8_17
URL : https://hal.archives-ouvertes.fr/hal-00866877
Adapting Spatial and Temporal Cases, International Conference for Case-Based Reasoning, pp.77-91, 2012. ,
DOI : 10.1007/978-3-642-32986-9_8
URL : https://hal.archives-ouvertes.fr/hal-00735231
INDu: An Interval & Duration Network, Advanced Topics in Artificial Intelligence, pp.291-303, 1999. ,
DOI : 10.1007/3-540-46695-9_25
On generalized interval calculi, Proceedings of the 9th National Conference of the American Association for Artificial Intelligence (AAAI), pp.234-240, 1991. ,
Using adaptation knowledge to retrieve and adapt design cases, Knowledge-Based Systems, vol.9, issue.2, pp.127-135, 1996. ,
DOI : 10.1016/0950-7051(95)01024-6
