New interface
Conference papers
An Image-Based Ensemble Kalman Filter for Motion Estimation
Abstract : This paper designs an Image-based Ensemble Kalman Filter (IEnKF), whose components are defined only from image properties, to estimate motion on image sequences. The key elements of this filter are, first, the construction of the initial ensemble, and second, the propagation in time of this ensemble on the studied temporal interval. Both are analyzed in the paper and their impact on results is discussed with synthetic and real data experiments. The initial ensemble is obtained by adding a Gaussian vector field to an estimate of motion on the first two frames. The standard deviation of this normal law is computed from motion results given by a set of optical flow methods of the literature. It describes the uncertainty on the motion value at initial date. The propagation in time of the ensemble members relies on the following evolution laws: transport by velocity of the image brightness function and Euler equations for the motion function. Shrinking of the ensemble is avoided thanks to a localization method and the use of observation ensembles, both techniques being defined from image characteristics. This Image-based Ensemble Kalman Filter is quantified on synthetic experiments and applied on traffic and meteorological images.
Document type :
Conference papers
Complete list of metadata
Cited literature [22 references]  Display  Hide  Download
https://hal.inria.fr/hal-01095360
Contributor : Nathalie Gaudechoux Connect in order to contact the contributor
Submitted on : Thursday, July 9, 2015 - 5:13:14 PM
Last modification on : Friday, January 21, 2022 - 3:21:44 AM
Long-term archiving on: : Wednesday, April 26, 2017 - 1:11:13 AM
File
Lepoittevin-Visapp-2015.pdf
Identifiers
Citation
Yann Lepoittevin, Isabelle Herlin, Dominique Béréziat. An Image-Based Ensemble Kalman Filter for Motion Estimation. VISAPP 2015 - 10th International Conference on Computer Vision Theory and Applications, Mar 2015, Berlin, Germany. pp.437-445, ⟨10.5220/0005259804370445⟩. ⟨hal-01095360⟩
Share
Metrics
Record views
369
Files downloads
334
