Trigonometrical form of zeta-function for negative (n) with proof for Riemann hypothesis.
The Riemann hypothesis is not proved by more, than 150 years. At this paper, I presented new solution for this problem. I found new trigonometrical form of Riemann's zeta function for negative numbers (n). This new form of zeta gives opportunity to prove the Riemann hypothesis. Presented proof isn’t complicated for trigonometrical form of zeta function.
