Procédé et système de traitement biologique pour bioprocédés continus susceptibles de présenter une inhibition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Brevet Année : 2013
The method comprises, given a value of a volume of reference (V) of a reactor supplied with a constant flow (Q), dividing the volume into a first digester of a first volume (V1) and a second digester of a second volume (V2) such that a sum of the first volume and the second volume is equal to that the volume of reference, inoculating the second digester by a microbial ecosystem to convert a part of a substrate and to present an inhibition of growth by the substrate in an initialization phase, dividing the flow into a first flow and a second flow such that the first flow supplies exclusively the first digester, and the second flow supplies initially second digester before being redistributed in the first digester. The method further comprises predetermining a target value of concentration in the substrate, in which the first volume (V1=rV) is a percentage volume of reference with r as a parameter, the second volume (V2=(1-r)V) is percentage complementary to the volume of reference, the second flow (Q2=alpha Q) is a percentage of the rate of constant flow with alpha as a parameter, and the first flow (Q1= (1-alpha )Q) is complementary percentage to the rate of constant flow; determining a dilution ratio of the second volume of the second digester and the dilution rate to be less than the value of the curve growth of the data on the microbial ecosystem for the given substrate; deducing a concentration value in the substrate corresponding to that of the dilution ratio from the growth curve; determining a set of values according to the value of the dilution rate and the value of the dilution ratio; choosing a subset of values from the determined set of values; determining a function representative of a speed or specific contribution in the substrate in the first digester at a given concentration based on a value of the parameter; selecting a value from the chosen values such that a variation curve of the function meets a graph of the function at more than one point; selecting a value from the chosen values such that the variation curve of the function does not meet a graph of the function at more than one point as the single point corresponds to a value of concentration in the weakest possible substrate; comparing the output concentration with the target value; and modifying the value of the parameter and/or the dilution ratio according to the result of the comparison. The volume of reference is equal to the rate of constant flow divided by a dilution rate, where the dilution rate is equal to a value of curve growth on microbial ecosystem data for the given substrate at a predetermined target value. An independent claim is included for an effluent treatment system.
L'invention concerne un bioprocédé continu de traitement d'un effluent à débit d'alimentation (Q) constant et comprenant un substrat à une concentration d'entrée (Sin) et de sortie (S**) ; comprenant des étapes consistant à : - déterminer un volume de référence (V) d'un réacteur alimenté par le débit (Q), - scinder le volume (V) en un premier digesteur de premier volume (V1) et un deuxième digesteur de deuxième volume (V2), tels que le premier volume (V1) plus deuxième volume (V2) égalent ledit volume (V), - ensemencer préalablement au moins le deuxième digesteur par un écosystème microbien susceptible de convertir ledit substrat et de présenter une inhibition de croissance ; - distribuer ledit débit (Q) en : o un premier débit (Q1) alimentant exclusivement le premier digesteur et un deuxième débit (Q2) alimentant d'abord le deuxième digesteur avant le premier digesteur.
BrevetFR_2986522_A1_1.pdf (956.55 Ko) Télécharger le fichier
hal-01095712 , version 1 (06-06-2020)
  • HAL Id : hal-01095712 , version 1
  • PRODINRA : 221658
Alain Rapaport, Jerome J. Harmand, Ihab Haidar. Procédé et système de traitement biologique pour bioprocédés continus susceptibles de présenter une inhibition. France, N° de brevet: FR 2 986 522 - 12 51140. 2013. ⟨hal-01095712⟩
367 Consultations
68 Téléchargements
