Relationship Between MDCT-Imaged Myocardial Fat and Ventricular Tachycardia Substrate in Arrhythmogenic Right Ventricular Cardiomyopathy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of the American Heart Association Année : 2014
Y. Komatsu
  • Fonction : Auteur
F. Sacher
  • Fonction : Auteur
A. Denis
M. Daly
N. Derval
  • Fonction : Auteur
A. Shah
  • Fonction : Auteur
C.-I. Park
  • Fonction : Auteur
J. Relan
  • Fonction : Auteur
M. Montaudon
  • Fonction : Auteur
F. Laurent
  • Fonction : Auteur
M. Hocini
  • Fonction : Auteur
M. Haissaguerre
  • Fonction : Auteur
P. Jais
  • Fonction : Auteur
Hubert Cochet
  • Fonction : Auteur
  • PersonId : 880054
Background-—Myocardial fibrofatty infiltration is a milieu for ventricular tachycardia (VT) in arrhythmogenic right ventricular cardiomyopathy (ARVC) and can be depicted as myocardial hypodensity on contrast-enhanced multidetector computed tomography (MDCT) with high spatial and temporal resolution. This study aimed to assess the relationship between MDCT-imaged myocardial fat and VT substrate in ARVC. Methods and Results-—We studied 16 patients with ARVC who underwent ablation and preprocedural MDCT. High-resolution imaging data were processed and registered to high-density endocardial and epicardial maps in sinus rhythm on 3-dimensional electroanatomic mapping (3D-EAM) (626AE335 and 575AE279 points/map, respectively). Analysis of the locations of low-voltage and fat segmentation included the following endocardial and epicardial regions: apex, mid (anterior, lateral, inferior), and basal (anterior, lateral, inferior). The location of local abnormal ventricular activities (LAVA) was compared with fat distribution. RV myocardial fat was successfully segmented and integrated with 3D-EAM in all patients. The j agreement test demonstrated a good concordance between the epicardial low voltage and fat (j=0.69, 95% CI 0.54 to 0.84), but fair concordance with the endocardium (j=0.41, 95% CI 0.27 to 0.56). The majority of LAVA (520/653 [80%]) were located within the RV fat segmentation, of which 90% were not farther than 20 mm from its border. Registration of MDCT allowed direct visualization of the coronary arteries, thus avoiding coronary damage during epicardial radiofrequency delivery.
vkIwAd-J Am Heart Assoc-2014-Komatsu-.pdf (1.62 Mo) Télécharger le fichier
hal-01095772 , version 1 (16-12-2014)
Y. Komatsu, A. Jadidi, F. Sacher, A. Denis, M. Daly, et al.. Relationship Between MDCT-Imaged Myocardial Fat and Ventricular Tachycardia Substrate in Arrhythmogenic Right Ventricular Cardiomyopathy. Journal of the American Heart Association, 2014, 3 (4), pp.10. ⟨10.1161/JAHA.114.000935⟩. ⟨hal-01095772⟩
Collections
INRIA INRIA2 ANR
158 Consultations
274 Téléchargements
