Lattice-based biclustering using Partition Pattern Structures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Victor Codocedo
Amedeo Napoli
In this work we present a novel technique for exhaustive bicluster enumeration using formal concept anal-ysis (FCA). Particularly, we use pattern structures (an ex-tension of FCA dealing with complex data) to mine similar row/column biclusters, a specialization of biclustering when attribute values have coherent variations. We show how bi-clustering can benefit from the FCA framework through its ro-bust theoretical description and efficient algorithms. Finally, we evaluate our bicluster mining approach w.r.t. a standard biclustering technique showing very good results in terms of bicluster quality and performance.
ecai2014.pdf (385.2 Ko) Télécharger le fichier
hal-01095865 , version 1 (16-12-2014)
Victor Codocedo, Amedeo Napoli. Lattice-based biclustering using Partition Pattern Structures. ECAI 2014 - 21st European Conference on Artificial Intelligence, 18-22 August 2014, Prague, Czech Republic - Including Prestigious Applications of Intelligent Systems (PAIS) 2014, Aug 2014, Prague, Czech Republic. ⟨10.3233/978-1-61499-419-0-213⟩. ⟨hal-01095865⟩
177 Consultations
280 Téléchargements
