Dynamic Packing with Side Constraints for Datacenter Resource Management - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2015
Resource management in datacenters involves assigning virtual machines with changing resource demands to physical machines with changing capacities. Recurrently, the changes invalidate the assignment and the resource manager recomputes it at runtime. The assignment is also subject to changing restrictions expressing a variety of user requirements. The present chapter surveys this application of vector packing—called the VM reassignment problem—with an insight into its dynamic and heterogeneous nature. We advocate flexibility to answer these issues and present BtrPlace, a flexible and scalable heuristic solution based on Constraint Programming.
Fichier non déposé
hal-01224870 , version 1 (05-11-2015)
Sophie Demassey, Fabien Hermenier, Vincent Kherbache. Dynamic Packing with Side Constraints for Datacenter Resource Management. Giorgio Fasano, János D. Pintér. Optimized Packings with Applications, 105, Springer International Publishing, pp.19-35, 2015, Springer Optimization and Its Applications, 978-3-319-18899-7. ⟨10.1007/978-3-319-18899-7_2⟩. ⟨hal-01224870⟩
457 Consultations
0 Téléchargements
