Heteroclinic cycles in Hopfield networks
Learning or memory formation are associated with the strengthening of the synaptic connections between neurons according to a pattern reflected by the input. According to this theory a retained memory sequence is associated to a dynamic pattern of the associated neural circuit. In this work we consider a class of network neuron models, known as Hopfield networks, with a learning rule which consists of transforming an information string to a coupling pattern. Within this class of models we study dynamic patterns, known as robust heteroclinic cycles, and establish a tight connection between their existence and the structure of the coupling.
