Face Verification across Age Progression, PAMI, 2006. ,
Modeling and Detection of Wrinkles in Aging Human Faces Using Marked Point Processing, p.2012 ,
Shape Recognition using Curve Segment Hausdorff Distance, 2006. ,
Line-based object recognition using Hausdorff distance: from range images to molecular secondary structures, Image and Vision Computing, vol.23, issue.4, 2005. ,
DOI : 10.1016/j.imavis.2004.11.002
Comparison of recognition rates for top 2 methods for detected wrinkles ,
Efficiently Locating Objects Using the Hausdorff Distance, 1997. ,
A Multi-Resolution Dynamic Model for Face Aging Simulation, 2007 IEEE Conference on Computer Vision and Pattern Recognition, 2007. ,
DOI : 10.1109/CVPR.2007.383055
I. Camps,Line-based recognition using a multidimensional Hausdorff distance, PAMI, 1999. ,
URL : https://hal.archives-ouvertes.fr/hal-00370699
Facial marks: Soft biometric for face recognition, 2009 16th IEEE International Conference on Image Processing (ICIP), 2009. ,
DOI : 10.1109/ICIP.2009.5413921
URL : http://biometrics.cse.msu.edu/Publications/SoftBiometrics/JainParkFacemarks_ICIP09.pdf
Distinguishing identical twins by face recognition, 2011. ,
Analysis of facial features in identical twins, 2011 International Joint Conference on Biometrics (IJCB), 2011. ,
DOI : 10.1109/IJCB.2011.6117548
Performance evaluation of local appearance based periocular recognition, 2010 Fourth IEEE International Conference on Biometrics: Theory, Applications and Systems (BTAS), 2010. ,
DOI : 10.1109/BTAS.2010.5634536
Face Matching and Retrieval Using Soft Biometrics, IEEE Transactions on Information Forensics and Security, vol.5, issue.3, 2010. ,
DOI : 10.1109/TIFS.2010.2049842
URL : http://biometrics.cse.msu.edu/Publications/Face/ParkJainFaceSoftBio_TIFS10.pdf
BIOFACE, Proceedings of the international conference on Multimedia, MM '10, 2010. ,
DOI : 10.1145/1873951.1874301
A modified Hausdorff distance for object matching, Proceedings of 12th International Conference on Pattern Recognition, 1994. ,
DOI : 10.1109/ICPR.1994.576361
