Journal articles
Identification of the Thermophysical Properties of the Soil by Inverse Problem
Salwa Mansour 1 Édouard Canot 1 Mohamad Muhieddine 2
1 SAGE - Simulations and Algorithms on Grids for Environment
Inria Rennes – Bretagne Atlantique , IRISA-D1 - SYSTÈMES LARGE ÉCHELLE
Abstract : This paper introduces a numerical strategy to estimate the thermophysical properties of a saturated porous medium (volumetric heat capacity (ρC)s , thermal conductivity λs and porosity φ) where a phase change problem (liquid/vapor) appears due strong heating. The estimation of these properties is done by inverse problem knowing the heating curves at selected points of the medium. To solve the inverse problem, we use both the Damped Gauss Newton and the Levenberg Marquardt methods to deal with high nonlinearity of the system and to tackle the problem with large residuals. We use the method of lines, where time and space discretizations are considered separately. Special attention has been paid to the choice of the regularization parameter of the Apparent Heat Capacity method which may prevent the convergence of the inverse problem.
Complete list of metadata
Cited literature [12 references]  Display  Hide  Download
https://hal.inria.fr/hal-01096787
Contributor : Édouard Canot Connect in order to contact the contributor
Submitted on : Thursday, December 17, 2015 - 3:35:04 PM
Last modification on : Friday, July 8, 2022 - 10:08:09 AM
Long-term archiving on: : Saturday, April 29, 2017 - 6:42:29 PM
File
HT-14-1585.pdf
Identifiers
Citation
Salwa Mansour, Édouard Canot, Mohamad Muhieddine. Identification of the Thermophysical Properties of the Soil by Inverse Problem. Journal of Heat Transfer, American Society of Mechanical Engineers, 2016, 138 (9), pp.091010. ⟨10.1115/1.4032947⟩. ⟨hal-01096787⟩
Share
Metrics
Record views
241
Files downloads
210
