New interface
Journal articles
Greedy routing in small-world networks with power-law degrees
Pierre Fraigniaud 1, 2 George Giakkoupis 3
2 GANG - Networks, Graphs and Algorithms
LIAFA - Laboratoire d'informatique Algorithmique : Fondements et Applications, Inria Paris-Rocquencourt
3 ASAP - As Scalable As Possible: foundations of large scale dynamic distributed systems
Inria Rennes – Bretagne Atlantique , IRISA-D1 - SYSTÈMES LARGE ÉCHELLE
Abstract : In this paper we study decentralized routing in small-world networks that combine a wide variation in node degrees with a notion of spatial embedding. Specifically, we consider a variant of J. Kleinberg's grid-based small-world model in which (1) the number of long-range edges of each node is not fixed, but is drawn from a power-law probability distribution with exponent parameter α ≥ 0 and constant mean, and (2) the long-range edges are considered to be bidirectional for the purposes of routing. This model is motivated by empirical observations indicating that several real networks have degrees that follow a power-law distribution. The measured power-law exponent α for these networks is often in the range between 2 and 3. For the small-world model we consider, we show that when 2 < α < 3 the standard greedy routing algorithm, in which a node forwards the message to its neighbor that is closest to the target in the grid, finishes in an expected number of O(log^(α−1) n · log log n) steps, for any source–target pair. This is asymptotically smaller than the O(log^2 n) steps needed in Kleinberg's original model with the same average degree, and approaches O(log n) as α approaches 2. Further, we show that when 0 ≤ α < 2 or α ≥ 3 the expected number of steps is O(log^2 n), while for α = 2 it is O(log^(4/3) n). We complement these results with lower bounds that match the upper bounds within at most a log log n factor.
Document type :
Journal articles
Complete list of metadata
Cited literature [38 references]  Display  Hide  Download
https://hal.inria.fr/hal-01097141
Contributor : George Giakkoupis Connect in order to contact the contributor
Submitted on : Friday, December 19, 2014 - 12:32:10 AM
Last modification on : Friday, January 21, 2022 - 3:13:37 AM
Long-term archiving on: : Monday, March 23, 2015 - 5:31:05 PM
File
DIST14_sw.pdf
Identifiers
Citation
Pierre Fraigniaud, George Giakkoupis. Greedy routing in small-world networks with power-law degrees. Distributed Computing, 2014, 27 (4), pp.231 - 253. ⟨10.1007/s00446-014-0210-y⟩. ⟨hal-01097141⟩
Share
Metrics
Record views
237
Files downloads
226
