Making objects writable, Proceedings of the 2014 ACM symposium on Principles of distributed computing, PODC '14, pp.385-395, 2014. ,
DOI : 10.1145/2611462.2611483
Sub-logarithmic Test-and-Set against a Weak Adversary, Proc. 25th DISC, pp.97-109, 2011. ,
DOI : 10.1007/s004460200071
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.225.604
Shared-memory mutual exclusion: major research trends since 1986, Distributed Computing, pp.75-110, 2003. ,
DOI : 10.1007/s00446-003-0088-6
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.138.1589
Fast and Scalable Mutual Exclusion, Proc. 13th DISC, pp.180-194, 1999. ,
DOI : 10.1007/3-540-48169-9_13
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.43.3306
The performance of spin lock alternatives for shared-money multiprocessors, IEEE Transactions on Parallel and Distributed Systems, vol.1, issue.1, pp.6-16, 1990. ,
DOI : 10.1109/71.80120
Faster randomized consensus with an oblivious adversary, Proc. 31st PODC, pp.1-8, 2012. ,
An O(1)-barriers optimal RMRs mutual exclusion algorithm, Proceedings of the 2013 ACM symposium on Principles of distributed computing, PODC '13, pp.220-229, 2013. ,
DOI : 10.1145/2484239.2484255
Tight RMR lower bounds for mutual exclusion and other problems, Proc. 40th STOC, pp.217-226, 2008. ,
Mutual Exclusion with O(log^2 Log n) Amortized Work, 2011 IEEE 52nd Annual Symposium on Foundations of Computer Science, pp.728-737, 2011. ,
DOI : 10.1109/FOCS.2011.84
Parallel Computer Architecture: A Hardware/Software Approach The communication requirements of mutual exclusion, [13] R. Cypher Proc. 7th SPAA, pp.147-156, 1995. ,
Closing the complexity gap between FCFS mutual exclusion and mutual exclusion, Distributed Computing, pp.87-111, 2010. ,
Brief Announcement: Local-Spin Algorithms for Abortable Mutual Exclusion and Related Problems, Proc. 22nd DISC, pp.512-513, 2008. ,
DOI : 10.1007/978-3-540-87779-0_41
Solution of a problem in concurrent programming control, Communications of the ACM, vol.8, issue.9, p.569, 1965. ,
DOI : 10.1145/365559.365617
) lower bound on the cost of mutual exclusion, Proceedings of the twenty-fifth annual ACM symposium on Principles of distributed computing , PODC '06, pp.275-284, 2006. ,
DOI : 10.1145/1146381.1146423
On the time and space complexity of randomized test-and-set, Proceedings of the 2012 ACM symposium on Principles of distributed computing, PODC '12, pp.19-28, 2012. ,
DOI : 10.1145/2332432.2332436
URL : https://hal.archives-ouvertes.fr/hal-00722947
RMRefficient implementations of comparison primitives using read and write operations, Distributed Computing, pp.109-162, 2012. ,
Linearizable implementations do not suffice for randomized distributed computation, Proceedings of the 43rd annual ACM symposium on Theory of computing, STOC '11, pp.373-382, 2011. ,
DOI : 10.1145/1993636.1993687
Adaptive randomized mutual exclusion in sub-logarithmic expected time, Proceeding of the 29th ACM SIGACT-SIGOPS symposium on Principles of distributed computing, PODC '10, pp.141-150, 2010. ,
DOI : 10.1145/1835698.1835737
The art of multiprocessor programming, Proceedings of the twenty-fifth annual ACM symposium on Principles of distributed computing , PODC '06, 2008. ,
DOI : 10.1145/1146381.1146382
Adaptive and efficient abortable mutual exclusion, Proceedings of the twenty-second annual symposium on Principles of distributed computing , PODC '03, pp.295-304, 2003. ,
DOI : 10.1145/872035.872079
Read/write based fastpath transformation for FCFS mutual exclusion, Proc. 31st SOFSEM, pp.209-218, 2005. ,
A time complexity bound for adaptive mutual exclusion, Proc. 15th DISC, pp.1-15, 2001. ,
Transformations of mutual exclusion algorithms from the cache-coherent model to the distributed shared memory model, Proc. 25th ICDCS, pp.261-270, 2005. ,
Distributed Algorithms, 1996. ,
Algorithms for scalable synchronization on shared-memory multiprocessors, ACM Transactions on Computer Systems, vol.9, issue.1, pp.21-65, 1991. ,
DOI : 10.1145/103727.103729
RMR-Efficient Randomized Abortable Mutual Exclusion, Proc. 26th DISC, pp.267-281, 2012. ,
DOI : 10.1007/978-3-642-33651-5_19
URL : http://arxiv.org/abs/1208.1723
A fast, scalable mutual exclusion algorithm, Distributed Computing, pp.51-60, 1995. ,
DOI : 10.1007/BF01784242
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.34.8678
