Conference papers
HRTF Magnitude Synthesis via Sparse Representation of Anthropometric Features
Abstract : We propose a method for the synthesis of the magnitudes of Head-related Transfer Functions (HRTFs) using a sparse representation of anthropometric features. Our approach treats the HRTF synthesis problem as finding a sparse representation of the subject's anthropometric features w.r.t. the anthropometric features in the training set. The fundamental assumption is that the magnitudes of a given HRTF set can be described by the same sparse combination as the anthropometric data. Thus, we learn a sparse vector that represents the subject's anthropometric features as a linear superposition of the anthropometric features of a small subset of subjects from the training data. Then, we apply the same sparse vector directly on the HRTF tensor data. For evaluation purpose we use a new dataset, containing both anthropometric features and HRTFs. We compare the proposed sparse representation based approach with ridge regression and with the data of a manikin (which was designed based on average anthropometric data), and we simulate the best and the worst possible classifiers to select one of the HRTFs from the dataset. For instrumental evaluation we use log-spectral distortion. Experiments show that our sparse representation outperforms all other evaluated techniques, and that the synthesized HRTFs are almost as good as the best possible HRTF classifier.
Document type :
Conference papers
Complete list of metadata
Cited literature [21 references]  Display  Hide  Download
https://hal.inria.fr/hal-01097303
Contributor : Piotr Bilinski Connect in order to contact the contributor
Submitted on : Friday, December 19, 2014 - 1:42:46 PM
Last modification on : Saturday, June 25, 2022 - 11:15:32 PM
Long-term archiving on: : Monday, March 23, 2015 - 5:51:21 PM
File
Piotr Bilinski - ICASSP 2014 -...
Copyright
Identifiers
Collections
Citation
Piotr Bilinski, Jens Ahrens, Mark R. P. Thomas, Ivan J. Tashev, John C. Platt. HRTF Magnitude Synthesis via Sparse Representation of Anthropometric Features. IEEE International Conference on Acoustics, Speech, and Signal Processing (ICASSP), May 2014, Florence, Italy. pp.4468 - 4472, ⟨10.1109/ICASSP.2014.6854447⟩. ⟨hal-01097303⟩
Share
Metrics
Record views
217
Files downloads
796
