On variations of the subset sum problem, Discrete Applied Mathematics, vol.81, issue.1-3, pp.1-7, 1998. ,
DOI : 10.1016/S0166-218X(96)00105-9
The Diophantine Frobenius Problem, Oxford Lecture Series in Mathematics and Its Applications, 2005. ,
Étude des systèmes algébriques surdéterminés. applications aux codes correcteurs et à la cryptographie, 2004. ,
On the Complexity of the F5 Gröbner basis Algorithm, Journal of Symbolic Computation, pp.1-24, 2014. ,
Asymptotic behaviour of the degree of regularity of semi-regular polynomial systems, MEGA'05, 2005. Eighth International Symposium on Effective Methods in Algebraic Geometry, 2005. ,
of Graduate Texts in Mathematics computational approach to commutative algebra, In cooperation with Heinz Kredel. URL http, Gröbner bases, vol.141, pp.978-979, 1993. ,
The Magma Algebra System I: The User Language, Journal of Symbolic Computation, vol.24, issue.3-4, pp.235-265, 1993. ,
DOI : 10.1006/jsco.1996.0125
A theoretical basis for the reduction of polynomials to canonical forms, ACM SIGSAM Bulletin, vol.10, issue.3, pp.19-29, 1976. ,
DOI : 10.1145/1088216.1088219
Multigraded Hilbert functions and Buchberger algorithm, Proceedings of the 1996 international symposium on Symbolic and algebraic computation , ISSAC '96, pp.72-78, 1996. ,
DOI : 10.1145/236869.236901
Converting bases with the Gröbner walk, Journal of Symbolic Computation, vol.24, pp.3-4, 1997. ,
Computations in weighted polynomial rings, Analele Stiintifice ale Universitatii Ovidius Constanta, vol.14, issue.2, pp.31-44, 2006. ,
Gröbner bases for codes. No. 4 in Algorithms and Computation in Mathematics, pp.237-259, 1999. ,
Singular 3-1-6 ? A computer algebra system for polynomial computations, 2012. ,
Solving Polynomial Equations: Foundations, Algorithms , and Applications, 2010. ,
Commutative algebra of Graduate Texts in Mathematics, pp.978-979, 1995. ,
A new efficient algorithm for computing Gröbner bases (F 4 ), algebraic geometry, pp.61-88, 1998. ,
A new efficient algorithm for computing Gröbner bases without reduction to zero (F 5 ), Proceedings of the 2002 International Symposium on Symbolic and Algebraic Computation, pp.75-83, 2002. ,
Efficient Computation of Zero-dimensional Gr??bner Bases by Change of Ordering, Journal of Symbolic Computation, vol.16, issue.4, pp.329-344, 1993. ,
DOI : 10.1006/jsco.1993.1051
On the complexity of computing Gröbner bases for quasi-homogeneous systems, Proceedings of the 2013 International Symposium on Symbolic and Algebraic Computation. ISSAC '13, 2013. ,
FGb: A Library for Computing Gr??bner Bases, Mathematical Software -ICMS 2010, 2010. ,
DOI : 10.1007/978-3-642-15582-6_17
Using Symmetries in the Index Calculus for Elliptic Curves Discrete Logarithm, Journal of Cryptology, vol.32, issue.1, pp.1-41, 2013. ,
DOI : 10.1007/s00145-013-9158-5
An inequality for Hilbert series of graded algebras., MATHEMATICA SCANDINAVICA, vol.56, pp.117-144, 1985. ,
DOI : 10.7146/math.scand.a-12092
Index calculus for abelian varieties of small dimension and the elliptic curve discrete logarithm problem, gröbner Bases in Cryptography, Coding Theory, and Algebraic Combinatorics. URL http, pp.1690-1702, 2009. ,
DOI : 10.1016/j.jsc.2008.08.005
URL : https://hal.archives-ouvertes.fr/inria-00337631
Macaulay2, a software system for research in algebraic geometry, 2014. ,
FGLM-Like Decoding: from Fitzpatrick???s Approach to Recent Developments, Gröbner Bases, Coding, and Cryptography, pp.197-218978, 2009. ,
DOI : 10.1007/978-3-540-93806-4_12
A weighted module view of integral closures of affine domains of type I, Advances in Mathematics of Communications, vol.3, issue.1, pp.1-11, 2009. ,
DOI : 10.3934/amc.2009.3.1
Algebraic geometry (v5.22) Available at www.jmilne.org/math, 2012. ,
Autour de la fonction de Hilbert-Samuel (escaliers d'idéaux polynomiaux), p.151245, 1991. ,
Revlex standard bases of generic complete intersections, 1996. ,
Degrevlex Gr??bner bases of generic complete intersections, Journal of Pure and Applied Algebra, vol.180, issue.3, pp.263-283, 2003. ,
DOI : 10.1016/S0022-4049(02)00297-9
An introduction to the theory of numbers, 1991. ,
Generic sequences of polynomials, Journal of Algebra, vol.324, issue.4, pp.579-590, 2010. ,
DOI : 10.1016/j.jalgebra.2010.04.018
On complete intersections and their Hilbert functions, Bulletin canadien de math??matiques, vol.34, issue.4, pp.525-535, 1991. ,
DOI : 10.4153/CMB-1991-083-9
Algorithms in Invariant Theory (Texts and Monographs in Symbolic Computation, 2008. ,
Hilbert Functions and the Buchberger Algorithm, Journal of Symbolic Computation, vol.22, issue.4, pp.355-376, 1996. ,
DOI : 10.1006/jsco.1996.0056
