Some experiments investigating a possible L(1/4) algorithm for the discrete logarithm problem in algebraic curves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
The function field sieve, a subexponential algorithm of complexity L(1/3) that computes discrete logarithms in finite fields, has recently been improved to an algorithm of complexity L(1/4) and subsequently to a quasi-polynomial time algorithm. We investigate whether the new ideas also apply to index calculus algorithms for computing discrete logarithms in Jacobians of algebraic curves. While we do not give a final answer to the question, we discuss a number of ideas, experiments, and possible conclusions.
paper.pdf (351.17 Ko) Télécharger le fichier
hal-01097362 , version 1 (19-12-2014)
  • HAL Id : hal-01097362 , version 1
Maike Massierer. Some experiments investigating a possible L(1/4) algorithm for the discrete logarithm problem in algebraic curves. 2014. ⟨hal-01097362⟩
216 Consultations
91 Téléchargements
