Trace Zero Varieties over Fields of Characteristic 2 for Cryptographic Applications, Algebraic Geometry and Its Applications, pp.188-215, 2007. ,
DOI : 10.1142/9789812793430_0010
Handbook of elliptic and hyperelliptic curve cryptography, Discrete Mathematics and its Applications, 2006. ,
High-Performance Scalar Multiplication Using 8-Dimensional GLV/GLS Decomposition, Cryptographic Hardware and Embedded Systems ? CHES 2013, pp.331-338, 2013. ,
DOI : 10.1007/978-3-642-40349-1_19
The Magma Algebra System I: The User Language, Journal of Symbolic Computation, vol.24, issue.3-4, pp.235-265, 1997. ,
DOI : 10.1006/jsco.1996.0125
High-speed high-security signatures, J. Cryptogr. Eng, vol.2, issue.2, pp.77-89, 2012. ,
Die Weil-Restriktion elliptischer Kurven in der Kryptographie, Master's thesis Voloch, Efficient computation of roots in finite fields, Des. Codes Crytogr, vol.39, issue.2, pp.275-280, 2002. ,
Computing in the Jacobian of a hyperelliptic curve, Math. Comp, vol.48, issue.177, pp.95-101, 1987. ,
Pairing with supersingular trace zero varieties revisited [Ces10] , Trace zero varieties in pairing-based cryptography The GHS attack in odd characteristic, Die03] C. Diem, pp.18-19, 2003. ,
An attack on a trace-zero cryptosystem ,
An L(1/3) Discrete Logarithm Algorithm for Low Degree Curves, Journal of Cryptology, vol.68, issue.226, pp.24-41, 2011. ,
DOI : 10.1007/s00145-010-9057-y
URL : https://hal.archives-ouvertes.fr/inria-00135324
Efficient and secure algorithms for GLV-based scalar multiplication and their implementation on GLV-GLS curves, Topics in cryptology CT-RSA 2014, LNCS, vol.8366, pp.1-27, 2014. ,
Applications of arithmetical geometry to cryptographic constructions, Proceedings of the 5th International Conference on Finite Fields and Applications, pp.128-161, 1999. ,
Fast genus 2 arithmetic based on Theta functions [Gau09] , Index calculus for abelian varieties of small dimension and the elliptic curve discrete logarithm problem, Gong and L. Harn, Public-key cryptosystems based on cubic finite field extensions, pp.243-265, 1999. ,
Constructive and destructive facets of Weil descent on elliptic curves, Journal of Cryptology, vol.44, issue.1, pp.19-46, 2002. ,
DOI : 10.1007/s00145-001-0011-x
URL : https://hal.archives-ouvertes.fr/inria-00512763
Computing pairings using x-coordinates only, Des. Codes Crytogr, pp.305-324, 2009. ,
Endomorphisms for Faster Elliptic Curve Cryptography on a Large Class of Curves, J. Cryptology, vol.47, issue.3, pp.446-469, 2011. ,
DOI : 10.1007/3-540-48892-8_15
Faster Point Multiplication on Elliptic Curves with Efficient Endomorphisms, Advances in Cryptology: Proceedings of CRYPTO '01, pp.190-200, 2001. ,
DOI : 10.1007/3-540-44647-8_11
Point compression for the trace zero subgroup over a small degree extension field, Des. Codes Crytogr, pp.335-357, 2015. ,
Modern computer algebra Two topics in hyperelliptic cryptography, Proceedings of SAC '01, pp.181-189, 1999. ,
CM-curves with good cryptographic properties Advances in Cryptology: Proceedings of CRYPTO '91, LNCS, vol.576, pp.179-287, 1991. ,
Trace zero subvarieties of genus 2 curves for cryptosystem, [Lan05] , Formulae for arithmetic on genus 2 hyperelliptic curvesLS12] P. Longa and F. Sica, Four-dimensional Gallant?Lambert?Vanstone scalar multiplication, Advances in Cryptology: Proceedings of ASIACRYPT '12, pp.15-33, 2001. ,
The XTR public key system Advances in Cryptology, Proceedings of CRYPTO '00 (M. Bellare, pp.1-19, 2000. ,
The Weil pairing, and its efficient calculation, Mon87] P. L. Montgomery, Speeding the Pollard and elliptic curve methods of factorization, pp.235-261, 1987. ,
Supersingular abelian varieties in cryptology Advances in Cryptology: Proceedings of CRYPTO '02, LNCS, vol.2442, pp.336-353, 2002. ,
Compression for trace zero subgroups of elliptic curves, Trends Math A public-key cryptosystem and a digital signature system based on the Lucas function analogue to discrete logarithms, Advances in Cryptology: Proceedings of ASIACRYPT '94 (J. Pieprzyk and R. Safavi-Naini, pp.93-100, 1995. ,
Elliptic Curves: Number Theory and Cryptography, second ed., Discrete Mathematics and its Applications, Wei01] A. Weimerskirch, corresponding v-polynomials. It follows that the overall complexity of decompression is O(log q) operations in F q, 2008. ,
Institut de mathématiques, Rue Emile-Argand, vol.11, 2000. ,
Rheinsprung 21, 4051 Basel, Switzer- land E-mail address: maike.massierer@inria ,
