Journal articles
Point compression for the trace zero subgroup over a small degree extension field
Abstract : Using Semaev's summation polynomials, we derive a new equation for the F_q-rational points of the trace zero variety of an elliptic curve defined over F_q. Using this equation, we produce an optimal-size representation for such points. Our representation is compatible with scalar multiplication. We give a point compression algorithm to compute the representation and a decompression algorithm to recover the original point (up to some small ambiguity). The algorithms are efficient for trace zero varieties coming from small degree extension fields. We give explicit equations and discuss in detail the practically relevant cases of cubic and quintic field extensions.
Document type :
Journal articles
Complete list of metadata
Cited literature [44 references]  Display  Hide  Download
https://hal.inria.fr/hal-01097434
Contributor : Maike Massierer Connect in order to contact the contributor
Submitted on : Tuesday, January 6, 2015 - 11:29:30 AM
Last modification on : Tuesday, December 17, 2019 - 10:10:03 AM
Long-term archiving on: : Wednesday, June 3, 2015 - 12:06:15 PM
File
paper.pdf
Identifiers
Collections
Citation
Elisa Gorla, Maike Massierer. Point compression for the trace zero subgroup over a small degree extension field. Designs, Codes and Cryptography, Springer Verlag, 2015, 75 (2), pp.335--357. ⟨10.1007/s10623-014-9921-0⟩. ⟨hal-01097434⟩
Share
Metrics
Record views
66
Files downloads
91
