Conference papers
Typical Worst Case Response-Time Analysis and its Use in Automotive Network Design
Abstract : For some automotive applications, worst case performance guarantees are too expensive, but a minimum level of performance must be formally guaranteed. For such applications, we have developed an approach called Typical Worst Case Analysis (TWCA) which can formally bound the number of violations of the computed response-time guarantee in a given time window. In this paper, we demonstrate how it can be used to analyze a real CAN bus with complex load patterns. We investigate the effects of these load patterns and show how the necessary parameters can be derived and verified from traces and specifications. We compare the results to the commonly used base load approximation --- like a 50%-limit for cyclic load --- showing superior accuracy and expressiveness.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-01097619
Contributor : Sophie Quinton <>
Submitted on : Saturday, December 20, 2014 - 10:55:16 AM
Last modification on : Monday, February 15, 2021 - 3:52:02 PM
Identifiers
Collections
Citation
Sophie Quinton, Julien Hennig, Torsten Bone, Moritz Neukirchner, Rolf Ernst, et al.. Typical Worst Case Response-Time Analysis and its Use in Automotive Network Design. The 51st Annual Design Automation Conference 2014, Jun 2014, San Francisco, CA, United States. ⟨10.1145/2593069.2602977⟩. ⟨hal-01097619⟩
Share
Metrics
Record views
507
