A point on fixpoints in posets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
Given a non-empty strictly inductive poset X, that is, a non-empty partially ordered set such that every non-empty chain has a least upper bound (a chain being a totally ordered subset), we are interested in sufficient conditions such that, given an element a_0 and a function f:X->X, there is some ordinal k such that a_{k+1}=a_k, where (a_k) is the transfinite sequence of iterates of f starting from a_0. This note summarizes known results about this problem and provides a slight generalization of some of them.
main.pdf (135.66 Ko) Télécharger le fichier
hal-01097809 , version 1 (22-12-2014)
  • HAL Id : hal-01097809 , version 1
Frédéric Blanqui. A point on fixpoints in posets. 2014. ⟨hal-01097809⟩
113 Consultations
376 Téléchargements
