Abstract : In this paper we study the question of life long learning of behaviors from human demonstrations by an intelligent system. One approach is to model the observed demonstrations by a stationary policy. Inverse rein-forcement learning, on the other hand, searches a reward function that makes the observed policy closed to optimal in the corresponding Markov decision process. This approach provides a model of the task solved by the demonstrator and has been shown to lead to better generalization in un-known contexts. However both approaches focus on learning a single task from the expert demonstration. In this paper we propose a feature learn-ing approach for inverse reinforcement learning in which several different tasks are demonstrated, but in which each task is modeled as a mixture of several, simpler, primitive tasks. We present an algorithm based on an al-ternate gradient descent to learn simultaneously a dictionary of primitive tasks (in the form of reward functions) and their combination into an ap-proximation of the task underlying observed behavior. We illustrate how this approach enables efficient re-use of knowledge from previous demon-strations. Namely knowledge on tasks that were previously observed by the learner is used to improve the learning of a new composite behavior, thus achieving transfer of knowledge between tasks.
https://hal.inria.fr/hal-01098040
Contributor : Olivier Mangin <>
Submitted on : Thursday, February 14, 2019 - 4:17:58 PM Last modification on : Wednesday, July 3, 2019 - 10:48:04 AM Long-term archiving on: : Wednesday, May 15, 2019 - 7:57:04 PM
