Abstract : We present an extension of superposition that natively handles a polymorphic type sys-tem extended with type classes, thus eliminating the need for type encodings when used by an interactive theorem prover like Isabelle/HOL. We describe syntax, typing rules, semantics, the polymorphic superposition calculus and an evaluation on a problem set that is generated from Isabelle/HOL theories. Our evaluation shows that native polymor-phic+typeclass performance compares favorably to monomorphisation, a highly efficient but incomplete way of dealing with polymorphism.
