Finite-time and fixed-time stabilization: Implicit Lyapunov function approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2015
Theorems on Implicit Lyapunov Functions (ILF) for finite-time and fixed-time stability analysis of nonlinear systems are presented. Based on these resutls, new nonlinear control laws are designed for robust stabilization of a chain of integrators. High order sliding mode (HOSM) algorithms are obtained as particular cases. Some aspects of digital implementations of the presented algorithms are studied, it is shown that they possess a chattering reduction ability. Theoretical results are supported by numerical simulations.
Automatique
FTCILF.pdf (737.4 Ko) Télécharger le fichier
hal-01098099 , version 1 (22-12-2014)
Andrey Polyakov, Denis Efimov, Wilfrid Perruquetti. Finite-time and fixed-time stabilization: Implicit Lyapunov function approach. Automatica, 2015, 51, pp.332 - 340. ⟨10.1016/j.automatica.2014.10.082⟩. ⟨hal-01098099⟩
1913 Consultations
3121 Téléchargements
