Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Journal articles
A Novel Approach for Detail-Enhanced Exposure Fusion Using Guided Filter
Harbinder Singh 1, * Vinay Kumar 1 Sunil Bhooshan 1
* Corresponding author
Abstract : In this paper we propose a novel detail-enhancing exposure fusion approach using nonlinear translation-variant filter (NTF). With the captured Standard Dynamic Range (SDR) images under different exposure settings, first the fine details are extracted based on guided filter. Next, the base layers (i.e., images obtained from NTF) across all input images are fused using multiresolution pyramid. Exposure, contrast, and saturation measures are considered to generate a mask that guides the fusion process of the base layers. Finally, the fused base layer is combined with the extracted fine details to obtain detail-enhanced fused image. The goal is to preserve details in both very dark and extremely bright regions without High Dynamic Range Image (HDRI) representation and tone mapping step. Moreover, we have demonstrated that the proposed method is also suitable for the multifocus image fusion without introducing artifacts.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-01098117
Contributor : Vinay Kumar Connect in order to contact the contributor
Submitted on : Monday, December 22, 2014 - 7:46:12 PM
Last modification on : Tuesday, April 17, 2018 - 11:52:01 AM
Long-term archiving on: : Monday, March 23, 2015 - 7:46:38 PM
File
659217.pdf
Publisher files allowed on an open archive
Identifiers
Citation
Harbinder Singh, Vinay Kumar, Sunil Bhooshan. A Novel Approach for Detail-Enhanced Exposure Fusion Using Guided Filter. The Scientific World Journal, Hindawi Publishing Corporation, 2014, pp.8. ⟨10.1155/2014/659217⟩. ⟨hal-01098117⟩
Share
Metrics
Record views
42
Files downloads
125
