Preprints, Working Papers, ...
Robustness of Performance and Stability for Multistep and Updated Multistep MPC Schemes
Abstract : We consider a model predictive control approach to approximate the solution of in nite horizon optimal control problems for perturbed nonlinear discrete time systems. By reducing the number of re-optimizations, the computational load can be lowered considerably at the expense of reduced robustness of the closed-loop solution against perturbations. In this paper, we propose and analyze an update strategy based on re-optimizations on shrinking horizons which is computationally less expensive than that based on full horizon re-optimization, and at the same time allowing for rigorously quanti able robust performance estimates
Document type :
Complete list of metadata
Cited literature [15 references]  Display  Hide  Download
https://hal.inria.fr/hal-01098334
Contributor : Estelle Bouzat Connect in order to contact the contributor
Submitted on : Monday, January 5, 2015 - 2:31:27 PM
Last modification on : Friday, October 13, 2017 - 5:08:16 PM
Long-term archiving on: : Thursday, September 10, 2015 - 11:45:16 PM
File
gruene_palma_multistep_preprin...
Identifiers
  • HAL Id : hal-01098334, version 1
Collections
Citation
Lars Grüne, Vryan Gil Palma. Robustness of Performance and Stability for Multistep and Updated Multistep MPC Schemes . 2014. ⟨hal-01098334⟩
Share
Metrics
Record views
50
Files downloads
192
