A Model-Based Certification Framework for the EnergyBus Standard - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The EnergyBus is an upcoming industrial standard for electric power transmission and management, based on the CANopen field bus. This paper reviews the particularities of the EnergyBus architecture and reports on the application of formal methods and protocol engineering tools to build a model-based conformance testing framework that is considered to become part of the certification process for EnergyBus-compliant products.
main.pdf (276.18 Ko) Télécharger le fichier
hal-01098360 , version 1 (11-03-2015)
Paternité
Alexander Graf-Brill, Holger Hermanns, Hubert Garavel. A Model-Based Certification Framework for the EnergyBus Standard. 34th Formal Techniques for Networked and Distributed Systems (FORTE), Jun 2014, Berlin, Germany. pp.84-99, ⟨10.1007/978-3-662-43613-4_6⟩. ⟨hal-01098360⟩
475 Consultations
923 Téléchargements
