Book sections
OpenCL: A suitable solution to simplify and unify High Performance Computing developments: A survey of OpenCL’s abstraction layers and high-level APIs
Abstract : Manycore architectures are now available in a wide range of HPC systems. Going from CPUs to GPUs and FPGAs, modern hardware accelerators can be exploited using heterogeneous software technologies. In this chapter, we study the inputs that OpenCL offers to High Performance Computing applications, as a solution to unify developments. In order to overcome the lack of native OpenCL support for some architectures, we survey the third-party research works that propose a source-to-source approach to transform OpenCL into other parallel programming languages. We use FPGAs as a case study, because of their dramatic OpenCL support compared to GPUs for instance. These transformation approaches could also lead to potential works in the Model Driven Engineering (MDE) field that we conceptualize on this work. Moreover, OpenCL's standard API is quite rough, thus we also introduce several APIs from the simple high-level binder to the source code generator that intend to ease and boost the development process of any OpenCL application.
Complete list of metadata
Cited literature [13 references]  Display  Hide  Download
https://hal.inria.fr/hal-01098581
Contributor : Jonathan Passerat-Palmbach Connect in order to contact the contributor
Submitted on : Friday, December 26, 2014 - 11:26:56 PM
Last modification on : Wednesday, May 25, 2022 - 10:54:03 AM
Long-term archiving on: : Saturday, April 15, 2017 - 11:50:14 AM
opengpu2012_frree.pdf
Identifiers
  • HAL Id : hal-01098581, version 1
Citation
Jonathan Passerat-Palmbach, David R.C. Hill. OpenCL: A suitable solution to simplify and unify High Performance Computing developments: A survey of OpenCL’s abstraction layers and high-level APIs. Frederic Magoules. Patterns for Parallel Programming on GPUs, Saxe-Coburg Publications, pp.189-209, 2014, 978-1-874672-57-9. ⟨hal-01098581⟩
Share
Metrics
Record views
207
Files downloads
814
