Construction of very high order residual distribution schemes for steady inviscid flow problems on hybrid unstructured meshes, Journal of Computational Physics, vol.230, issue.11, pp.4103-4136, 2011. ,
DOI : 10.1016/j.jcp.2010.07.035
URL : https://hal.archives-ouvertes.fr/hal-00652412
Tetrahedral mesh generation and optimization ,
PARALLEL MESH ADAPTATION, Applied and Industrial Mathematics in Italy, p.201, 2005. ,
DOI : 10.1142/9789812701817_0019
The dynamic adaptation of parallel mesh-based computation, SIAM 7th Symposium on Parallel and Scientific Computation, 1996. ,
Parallel Unstructured Mesh Adaptation Method for Moving Body Applications, AIAA Journal, vol.43, issue.9, pp.1937-1945, 2005. ,
DOI : 10.2514/1.7818
Parallel Delaunay mesh generation kernel, International Journal for Numerical Methods in Engineering, vol.177, issue.2, pp.161-176, 2003. ,
DOI : 10.1002/nme.765
A mesh improvement method for 3d automatic remeshing. Numerical Grid Generation in Computational Fluid Dynamics and Related Fields, pp.615-626, 1994. ,
Parallel meshing and remeshing, Applied Mathematical Modelling, vol.25, issue.2, pp.153-175, 2000. ,
DOI : 10.1016/S0307-904X(00)00045-7
URL : https://hal.archives-ouvertes.fr/hal-00536635
Computation of the signed distance function to a discrete contour on adapted triangulation, Calcolo, vol.74, issue.3, pp.193-219, 2012. ,
DOI : 10.1007/s10092-011-0051-z
Adaptation de maillage en paralì ele, applicationàapplication`applicationà la simulation de la mise en forme des matériaux, Congrès Français de Mécanique Grenoble-CFM 2007, 2007. ,
Object-oriented programming for " fast and easy " development of parallel applications in forming processes simulation. Computational Fluid And Solid Mechanics, Vols 1 and 2, Proceedings, 2003. ,
URL : https://hal.archives-ouvertes.fr/hal-00531577
Anisotropic Delaunay Mesh Adaptation for Unsteady Simulations, Proceedings of the 17th international Meshing Roundtable, pp.177-194, 2008. ,
DOI : 10.1007/978-3-540-87921-3_11
URL : https://hal.archives-ouvertes.fr/hal-00353786
Parallel mesh adaptation, International Journal for Numerical Methods in Engineering, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-01099259
Anisotropic mesh adaptation for cfd computations Computer methods in applied mechanics and engineering, pp.5068-5082, 2005. ,
Hybrid, viscous, unstructured mesh solver for propulsive applications, 34th AIAA/ASME/SAE/ASEE Joint Propulsion Conference and Exhibit, pp.98-3153, 1998. ,
DOI : 10.2514/6.1998-3153
Conception et validation d'algorithmes de remaillageparalì elesàelesà mémoire distribuée basés sur un remailleur séquentiel, 2013. ,
ParFUM: a parallel framework for unstructured meshes for scalable dynamic physics applications, Engineering with Computers, vol.15, issue.3-4, pp.215-235, 1007. ,
DOI : 10.1007/s00366-006-0039-5
PLUM : Parallel Load Balancing for Adaptive Unstructured Meshes, Journal of Parallel and Distributed Computing, vol.52, issue.2, pp.150-177, 1998. ,
DOI : 10.1006/jpdc.1998.1469
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.158.9552
Parallel tetrahedral mesh adaptation with dynamic load balancing, Parallel Computing, vol.26, issue.12, pp.1583-1608, 2000. ,
DOI : 10.1016/S0167-8191(00)00047-8
Scotch and PT-Scotch Graph Partitioning Software, Combinatorial Scientific Computing, pp.373-406, 2012. ,
DOI : 10.1201/b11644-15
URL : https://hal.archives-ouvertes.fr/hal-00770422
A parallel two mesh method for speeding-up processes with localized deformations: application to cogging, International Journal of Material Forming, vol.56, issue.S1, pp.581-584 ,
DOI : 10.1007/s12289-009-0440-x
URL : https://hal.archives-ouvertes.fr/hal-00509412
Parallel remeshing of unstructured volume grids for CFD applications, International Journal for Numerical Methods in Fluids, vol.45, issue.8, pp.1361-1379, 2007. ,
DOI : 10.1002/fld.1195
