A comparison of routing sets for robust network design
Designing a network able to route a set of non-simultaneous demand vectors is an important problem arising in telecommunications. In this paper, we compare the optimal capacity allocation costs for six routing sets: affine routing, volume routing and its two simplifications, the routing based on an unrestricted 2-cover of the uncertainty set, and the routing based on a cover delimited by a hyperplane.
Recherche opérationnelle [math.OC]
