Particle-imaging techniques for experimental fluid mechanics . Annual review of fluid mechanics, pp.261-304, 1991. ,
DOI : 10.1146/annurev.fl.23.010191.001401
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.57.5404
A vector spline approximation, Journal of Approximation Theory, vol.67, issue.1, pp.1-29, 1991. ,
DOI : 10.1016/0021-9045(91)90025-6
Dispersion of passive tracers in closed basins: Beyond the diffusion coefficient, Physics of Fluids, vol.9, issue.11, pp.9-3162, 1997. ,
DOI : 10.1063/1.869433
Mathematical Problems in Image Processing, 2006. ,
Predictability in the large: an extension of the concept of Lyapunov exponent, Journal of Physics A: Mathematical and General, vol.30, issue.1, pp.1-26, 1997. ,
DOI : 10.1088/0305-4470/30/1/003
Identification of velocity fields for geophysical fluids from a sequence of images, Experiments in Fluids, vol.28, issue.1, pp.313-328, 2010. ,
DOI : 10.1007/s00348-010-0926-9
URL : https://hal.archives-ouvertes.fr/hal-00905015
Mixing by low- and high-resolution surface geostrophic currents, Journal of Geophysical Research, vol.104, issue.C9, p.15, 2010. ,
DOI : 10.1029/2009JC006006
An Assessment of the Importance of Chaotic Stirring and Turbulent Mixing on the West Florida Shelf, Journal of Physical Oceanography, vol.39, issue.7, pp.1743-1755, 2009. ,
DOI : 10.1175/2009JPO4046.1
Surface Ocean Mixing Inferred from Different Multisatellite Altimetry Measurements, Journal of Physical Oceanography, vol.40, issue.11, pp.40-2466, 2010. ,
DOI : 10.1175/2010JPO4458.1
The Spatial Structure of Observation Errors in Atmospheric Motion Vectors from Geostationary Satellite Data, Monthly Weather Review, vol.131, issue.4, pp.706-718, 2003. ,
DOI : 10.1175/1520-0493(2003)131<0706:TSSOOE>2.0.CO;2
singularities, Communications on Pure and Applied Mathematics, vol.9, issue.7, pp.219-266, 2003. ,
DOI : 10.1002/cpa.10116
Image processing and analysis. variational, PDE, wavelet, and stochastic methods, 2005. ,
Pressure image assimilation for atmospheric motion estimation, Tellus A, vol.28, issue.3, pp.160-178, 2009. ,
DOI : 10.1111/j.1600-0870.2008.00370.x
URL : https://hal.archives-ouvertes.fr/inria-00273838
Mixing structures in the Mediterranean Sea from finite-size Lyapunov exponents Comparison between Eule¾¼ References rian diagnostics and finite-size Lyapunov exponents computed from altimetry in the Algerian basin. Deep Sea Research Part I: Oceanographic Research Papers, Cristóbal Geophys. Res. Lett, vol.31, issue.561, pp.15-31, 2004. ,
Lagrangian validation of the Mediterranean mean dynamic topography by extraction of tracer frontal structures, Mercator Ocean Quarterly Newsletter, vol.32, pp.24-32, 2009. ,
On the inversion of submesoscale tracer fields to estimate the surface ocean circulation, Journal of Marine Systems, vol.126, 2012. ,
DOI : 10.1016/j.jmarsys.2012.02.014
Stochastic Relaxation, Gibbs Distributions, and the Bayesian Restoration of Images, IEEE Trans. Pattern Anal. Mach. Intell, vol.6, pp.721-741, 1984. ,
Conditioning and preconditioning of the variational data assimilation problem, Computers & Fluids, vol.46, issue.1, pp.252-256, 2011. ,
DOI : 10.1016/j.compfluid.2010.11.025
Finding finite-time invariant manifolds in two-dimensional velocity fields, Chaos: An Interdisciplinary Journal of Nonlinear Science, vol.10, issue.1, pp.99-108, 2000. ,
DOI : 10.1063/1.166479
Lagrangian structures and the rate of strain in a partition of two-dimensional turbulence, Physics of Fluids, vol.13, issue.11, pp.13-3365, 2001. ,
DOI : 10.1063/1.1403336
Lagrangian coherent structures from approximate velocity data, Physics of Fluids, vol.14, issue.6, pp.1851-1861, 2002. ,
DOI : 10.1063/1.1477449
A variational theory of hyperbolic Lagrangian Coherent Structures, Physica D: Nonlinear Phenomena, vol.240, issue.7, pp.574-598, 2011. ,
DOI : 10.1016/j.physd.2010.11.010
Lagrangian coherent structures and mixing in two-dimensional turbulence, Physica D: Nonlinear Phenomena, vol.147, issue.3-4, pp.3-4, 2000. ,
DOI : 10.1016/S0167-2789(00)00142-1
Determining optical flow, Artificial Intelligence, vol.17, issue.1-3, pp.185-203, 1981. ,
DOI : 10.1016/0004-3702(81)90024-2
Retrieving ocean surface current by 4-D variational assimilation of sea surface temperature images, Remote Sensing of Environment, vol.112, issue.4, pp.1464-1475, 2008. ,
DOI : 10.1016/j.rse.2007.04.020
URL : https://hal.archives-ouvertes.fr/hal-00283896
Characterization of finite-time Lyapunov exponents and vectors in two-dimensional turbulence, Chaos: An Interdisciplinary Journal of Nonlinear Science, vol.12, issue.3, pp.688-699, 2002. ,
DOI : 10.1063/1.1499395
URL : https://hal.archives-ouvertes.fr/hal-00310234
Stirring of the northeast Atlantic spring bloom: A Lagrangian analysis based on multisatellite data, Journal of Geophysical Research, vol.14, issue.C4, p.15, 2007. ,
DOI : 10.1029/2006JC003927
URL : https://hal.archives-ouvertes.fr/hal-00770691
Remote impacts of Sub-Mesoscale Dynamics on new production, Mercator Ocean Quarterly Newsletter, vol.13, pp.13-17, 2009. ,
A wavelet tour of signal processing, 1998. ,
Uncovering the Lagrangian Skeleton of Turbulence, Physical Review Letters, vol.98, issue.14, pp.98-144502, 2007. ,
DOI : 10.1103/PhysRevLett.98.144502
Displacing Potential Vorticity Structures by the Assimilation of Pseudo-Observations, Monthly Weather Review, vol.139, issue.2, pp.549-565, 2011. ,
DOI : 10.1175/2010MWR3395.1
Automated tracking of dry intrusions on satellite water vapour imagery and model output, Quarterly Journal of the Royal Meteorological Society, vol.78, issue.620, pp.2257-2276, 2006. ,
DOI : 10.1256/qj.05.179
Fully automated cloud-drift winds in NESDIS operations, Bull. Amer. Meteor. Soc, vol.78, pp.1121-1133, 1997. ,
Tracing the early development of harmful algal blooms on the West Florida Shelf with the aid of Lagrangian coherent structures, Journal of Geophysical Research, vol.19, issue.C6, p.pp, 2008. ,
DOI : 10.1029/2007JC004533
Chaos in Dynamical Systems Chaos in Dynamical Systems, 1993. ,
The Kinematics of Mixing: Stretching, Chaos, and Transport Variational Assimilation of Fluid Motion from Image Sequence, SIAM J. on Imaging Sciences, vol.1, issue.4, pp.343-363, 1989. ,
Operational Cloud-Motion Winds from Meteosat Infrared Images, Journal of Applied Meteorology, vol.32, issue.7, pp.32-1206, 1993. ,
DOI : 10.1175/1520-0450(1993)032<1206:OCMWFM>2.0.CO;2
Definition and properties of Lagrangian coherent structures from finite-time Lyapunov exponents in two-dimensional aperiodic??flows, Physica D: Nonlinear Phenomena, vol.212, issue.3-4, pp.3-4, 2005. ,
DOI : 10.1016/j.physd.2005.10.007
The correlation between surface drifters and coherent structures based on high-frequency radar data in Monterey Bay, Deep Sea Research Part II: Topical Studies in Oceanography, vol.56, issue.3-5, pp.3-5, 2009. ,
DOI : 10.1016/j.dsr2.2008.08.008
November) Assimilation d'images pour les fluides géophysiques, 2010. ,
On the use of Finite-Time Lyapunov Exponents and Vectors for direct assimilation of tracer images into ocean models, Tellus A, vol.2, issue.3-5, pp.1038-1051, 2011. ,
DOI : 10.1111/j.1600-0870.2011.00533.x
Assimilation of image sequences in numerical models, Tellus A, vol.105, issue.C8, pp.30-47, 2010. ,
DOI : 10.1111/j.1600-0870.2009.00416.x
URL : https://hal.archives-ouvertes.fr/inria-00332815
Sea surface velocities from sea surface temperature image sequences: 1. Method and validation using primitive equation model output, Journal of Geophysical Research: Oceans, vol.28, issue.C8, pp.19499-19514, 2000. ,
DOI : 10.1029/2000JC900027
