A robust howling detection algorithm based on a statistical approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents an algorithm for the detection of howlings that arise in audio signals. Our method is based on the combination of two energy-based features and one new feature related to the frequency stability of a howling component. The decision stage, which implies a Support Vector Machine (SVM) model, outputs a decision every 20 ms. The evaluation, carried out on a large database, showed that the algorithm is able to detect both pure and multiple tones howling in a wide range of energy. Furthermore, even on complex signals such as music, the detection is still efficient with very few false alarms.
Fichier non déposé
hal-01100273 , version 1 (06-01-2015)
  • HAL Id : hal-01100273 , version 1
Joachim Flocon-Cholet, Julien Faure, Alexandre Guérin, Pascal Scalart. A robust howling detection algorithm based on a statistical approach. International Workshop on Acoustic Signal Enhancement (IWAENC), Sep 2014, Antibes, France. ⟨hal-01100273⟩
364 Consultations
0 Téléchargements
