Cavitation and Bubble Dynamics, 1995. ,
DOI : 10.1017/CBO9781107338760
URL : http://authors.library.caltech.edu/25017/1/cavbubdynam.pdf
Modelling phase transition in metastable liquids: application to cavitating and flashing flows, Journal of Fluid Mechanics, vol.15, pp.313-350, 2008. ,
DOI : 10.1017/S0022112087003227
URL : https://hal.archives-ouvertes.fr/inria-00333908
Analysis of Thermal Effects in a Cavitating Inducer Using Rayleigh Equation, Journal of Fluids Engineering, vol.129, issue.8, pp.974-983, 2007. ,
DOI : 10.1115/1.2746919
URL : https://hal.archives-ouvertes.fr/hal-00265809
Influence of convective heat transfer modeling on the estimation of thermal effects in cryogenic cavitating flows, International Journal of Heat and Mass Transfer, vol.55, issue.23-24, p.65386554, 2012. ,
DOI : 10.1016/j.ijheatmasstransfer.2012.06.060
URL : https://hal.archives-ouvertes.fr/hal-00710264
Thermodynamic Effects on Cavitation in Water and Cryogenic Fluids, ASME 2010 10th Biennial Conference on Engineering Systems Design and Analysis, Volume 3, pp.475-482 ,
DOI : 10.1115/ESDA2010-24694
A reduced-order model of diffusive effects on the dynamics of bubbles, Physics of Fluids, vol.19, issue.12, pp.123302-123313, 2007. ,
DOI : 10.1063/1.2825018
Numerical investigation of the hump characteristic of a pumpturbine based on an improved cavitation model, Computers & Fluids, issue.0, pp.68105-111, 2012. ,
Constraints on equation of state for cavitating flows with thermodynamic effects, Applied Mathematics and Computation, vol.217, issue.11, pp.5095-5102, 2011. ,
DOI : 10.1016/j.amc.2010.07.056
URL : https://hal.archives-ouvertes.fr/hal-00530263
Cavitation modeling in cryogenic fluids for liquid rocket engine applications. AIAA 38th Fluid Dynamics Conference and Exhibit, pp.23-26, 2008. ,
Robust analysis of cavitating flows in the Venturi tube, European Journal of Mechanics - B/Fluids, vol.44, pp.88-99, 2014. ,
DOI : 10.1016/j.euromechflu.2013.11.002
Shape Optimization for Cryogenic Cavitating Flows Past an Isolated Hydrofoil, Volume 1: Symposia, Parts A and B, pp.75-85, 2008. ,
DOI : 10.1115/FEDSM2008-55119
URL : https://hal.archives-ouvertes.fr/inria-00549317
A two-phase mixture theory for the deflagration-to-detonation transition (ddt) in reactive granular materials, International Journal of Multiphase Flow, vol.12, issue.6, pp.861-889, 1986. ,
DOI : 10.1016/0301-9322(86)90033-9
The discrete equation method (DEM) for fully compressible, two-phase flows in ducts of spatially varying cross-section, Nuclear Engineering and Design, vol.240, issue.11, pp.3797-3818, 2010. ,
DOI : 10.1016/j.nucengdes.2010.08.003
Two-phase flow numerical simulation with real-gas effects and occurrence of rarefaction shock waves, European Journal of Mechanics - B/Fluids, vol.45, pp.20-35, 2014. ,
DOI : 10.1016/j.euromechflu.2013.11.007
URL : https://hal.archives-ouvertes.fr/hal-00911766
A five equation reduced model for compressible two phase flow problems, Journal of Computational Physics, vol.202, issue.2, pp.664-698, 2005. ,
DOI : 10.1016/j.jcp.2004.07.019
URL : https://hal.archives-ouvertes.fr/hal-00871724
Modeling for non isothermal cavitation using 4-equation models, International Journal of Heat and Mass Transfer, vol.76, pp.247-262, 2014. ,
DOI : 10.1016/j.ijheatmasstransfer.2014.04.065
URL : https://hal.archives-ouvertes.fr/hal-00990670
A multiphase model for compressible flows with interfaces, shocks, detonation waves and cavitation, Journal of Fluid Mechanics, vol.431, pp.239-271, 2001. ,
DOI : 10.1017/S0022112000003098
Discrete Equation Method (DEM) for the simulation of viscous, compressible, two-phase flows, Computers & Fluids, vol.91, issue.0, pp.91164-181, 2014. ,
DOI : 10.1016/j.compfluid.2013.11.028
URL : https://hal.archives-ouvertes.fr/hal-00911769
Modeling phase transition for compressible two-phase flows applied to metastable liquids, Journal of Computational Physics, vol.229, issue.8, pp.2964-2998, 2010. ,
DOI : 10.1016/j.jcp.2009.12.026
A mixture-energy-consistent six-equation two-phase numerical model for fluids with interfaces, cavitation and evaporation waves, Journal of Computational Physics, vol.259, pp.331-357, 2014. ,
DOI : 10.1016/j.jcp.2013.12.003
URL : https://hal.archives-ouvertes.fr/hal-01135994
Numerical experiments using a HLLC-type scheme with ALE formulation for compressible two-phase flows five-equation models with phase transition, Computers & Fluids, vol.94, issue.0, pp.94112-138, 2014. ,
DOI : 10.1016/j.compfluid.2014.02.008
Simulating cavitating liquid jets using a compressible and equilibrium two-phase flow solver, International Journal of Multiphase Flow, vol.63, issue.0, pp.52-67, 2014. ,
DOI : 10.1016/j.ijmultiphaseflow.2014.03.006
Towards an efficient simulation of cavitating flows with real gas effects and uncertainty quantification, WCCM XI-ECCM V-ECFD VI, pp.4779-4790, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01092332
Approximation of liquid???vapor phase transition for compressible fluids with tabulated EOS, Comptes Rendus Mathematique, vol.348, issue.7-8, pp.473-478, 2010. ,
DOI : 10.1016/j.crma.2010.01.012
URL : https://hal.archives-ouvertes.fr/hal-00976950
Asymptotic expansion of multiscale numerical scheme for compressible multiscale flow [27] R. Saurel and R. Abgrall. A multiphase godunov method for compressible multifluid and multiphase flows, SIAM Journal on Scientific Computing Journal of Computational Physics, vol.5, issue.150, pp.84-115425, 1999. ,
Two-phase modeling of deflagration-to-detonation transition in granular materials: Reduced equations, Physics of Fluids, vol.13, issue.10, pp.3002-3024, 2001. ,
DOI : 10.1063/1.1398042
Discrete equations for physical and numerical compressible multiphase mixtures, Journal of Computational Physics, vol.186, issue.2, pp.361-396, 2003. ,
DOI : 10.1016/S0021-9991(03)00011-1
A difference scheme for numerical computation of discontinuous solutions of equations of fluid dynamics, Math. Sbornik, vol.47, pp.271-306, 1959. ,
Relaxation of Energy and Approximate Riemann Solvers for General Pressure Laws in Fluid Dynamics, SIAM Journal on Numerical Analysis, vol.35, issue.6, pp.2223-2249, 1998. ,
DOI : 10.1137/S0036142997318528
Riemann Solvers and Numerical Methods for Fluid Dynamics, 1997. ,
Modelling and simulation of liquidvapor phase transition in compressible flows based on thermodynamical equilibrium, ESAIM:M2AN, pp.1029-1054, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00976983
Numerical simulation of cavitating flows with homogeneous models. Computers and Fluids, pp.1682-1696, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00530245
Shock jump relations for multiphase mixtures with stiff mechanical relaxation, Shock Waves, vol.56, issue.3, pp.209-232, 2007. ,
DOI : 10.1007/s00193-006-0065-7
Convex Entropies and Hyperbolicity for General Euler Equations, SIAM Journal on Numerical Analysis, vol.35, issue.6, pp.2117-2127, 1998. ,
DOI : 10.1137/S0036142997316700
A Godunov-type method for the seven-equation model of compressible two-phase flow, Computers & Fluids, vol.54, pp.67-91, 2012. ,
DOI : 10.1016/j.compfluid.2011.10.004
URL : https://hal.archives-ouvertes.fr/hal-00517375
Evaporation waves in superheated dodecane, Journal of Fluid Mechanics, vol.382, p.6386, 1999. ,
DOI : 10.1017/S0022112098003796
