New interface
Journal articles
Post-stroke balance rehabilitation under multi-level electrotherapy: a conceptual review
Anirban Dutta 1, * Uttama Lahiri 2 Abhijit Das 3 Michael Nitsche 4 David Guiraud 1
* Corresponding author
1 CAMIN - Control of Artificial Movement and Intuitive Neuroprosthesis
LIRMM - Laboratoire d'Informatique de Robotique et de Microélectronique de Montpellier, CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : Stroke is caused when an artery carrying blood from heart to an area in the brain bursts or a clot obstructs the blood flow thereby preventing delivery of oxygen and nutrients. About half of the stroke survivors are left with some degree of disability. Innovative methodologies for restorative neurorehabilitation are urgently required to reduce long-term disability. The ability of the nervous system to respond to intrinsic or extrinsic stimuli by reorganizing its structure, function, and connections is called neuroplasticity. Neuroplasticity is involved in post-stroke functional disturbances, but also in rehabilitation. It has been shown that active cortical participation in a closed-loop brain machine interface (BMI) can induce neuroplasticity in cortical networks where the brain acts as a controller, e.g., during a visuomotor task. Here, the motor task can be assisted with neuromuscular electrical stimulation (NMES) where the BMI will act as a real-time decoder. However, the cortical control and induction of neuroplasticity in a closed-loop BMI is also dependent on the state of brain, e.g., visuospatial attention during visuomotor task performance. In fact, spatial neglect is a hidden disability that is a common complication of stroke and is associated with prolonged hospital stays, accidents, falls, safety problems, and chronic functional disability. This hypothesis and theory article presents a multi-level electrotherapy paradigm toward motor rehabilitation in virtual reality that postulates that while the brain acts as a controller in a closed-loop BMI to drive NMES, the state of brain can be can be altered toward improvement of visuomotor task performance with non-invasive brain stimulation (NIBS). This leads to a multi-level electrotherapy paradigm where a virtual reality-based adaptive response technology is proposed for post-stroke balance rehabilitation. In this article, we present a conceptual review of the related experimental findings.
Document type :
Journal articles
Complete list of metadata
Cited literature [97 references]  Display  Hide  Download
https://hal.inria.fr/hal-01100748
Contributor : Anirban Dutta Connect in order to contact the contributor
Submitted on : Wednesday, January 7, 2015 - 5:26:35 AM
Last modification on : Wednesday, November 9, 2022 - 11:20:49 AM
Long-term archiving on: : Wednesday, April 8, 2015 - 11:19:41 AM
File
fnins-08-00403.pdf
Identifiers
Collections
Citation
Anirban Dutta, Uttama Lahiri, Abhijit Das, Michael Nitsche, David Guiraud. Post-stroke balance rehabilitation under multi-level electrotherapy: a conceptual review. Frontiers in Neuroscience, 2014, 8 (403), pp.1-18. ⟨10.3389/fnins.2014.00403⟩. ⟨hal-01100748⟩
Share
Metrics
Record views
200
Files downloads
274
