Sequence Classification Based on Delta-Free Sequential Pattern - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pierre Holat
Marc Plantevit
Chedy Raïssi
Nadi Tomeh
Thierry Charnois
Sequential pattern mining is one of the most studied and challenging tasks in data mining. However, the extension of well-known methods from many other classical patterns to sequences is not a trivial task. In this paper we study the notion of δ-freeness for sequences. While this notion has extensively been discussed for itemsets, this work is the first to extend it to sequences. We define an efficient algorithm devoted to the extraction of δ-free sequential patterns. Furthermore, we show the advantage of the δ-free sequences and highlight their importance when building sequence classifiers, and we show how they can be used to address the feature selection problem in statistical classifiers, as well as to build symbolic classifiers which optimizes both accuracy and earliness of predictions.
delta-libres.pdf (993.33 Ko) Télécharger le fichier
hal-01100929 , version 1 (07-01-2015)
Copyright (Tous droits réservés)
  • HAL Id : hal-01100929 , version 1
Pierre Holat, Marc Plantevit, Chedy Raïssi, Nadi Tomeh, Thierry Charnois, et al.. Sequence Classification Based on Delta-Free Sequential Pattern. IEEE International Conference on Data Mining, Dec 2014, Shenzhen, China. ⟨hal-01100929⟩
665 Consultations
468 Téléchargements
