A benchmark for surface reconstruction, ACM Transactions on Graphics, vol.32, issue.2, p.20, 2013. ,
DOI : 10.1145/2451236.2451246
High-resolution shape reconstruction from multiple range images based on simultaneous estimation of surface and motion, 2009 IEEE 12th International Conference on Computer Vision, pp.1787-1794, 2009. ,
DOI : 10.1109/ICCV.2009.5459399
A technique for finding the symmetry axes of implicit polynomial curves under perspective projection, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.27, issue.3, pp.465-470, 2005. ,
DOI : 10.1109/TPAMI.2005.45
A concept for parametric surface fitting which avoids the parametrization problem, Computer Aided Geometric Design, vol.20, issue.6, pp.343-362, 2003. ,
DOI : 10.1016/S0167-8396(03)00078-5
Bayesian surface reconstruction via iterative scan alignment to an optimized prototype, Symposium on Geometry Processing, pp.213-223, 2007. ,
A Fast Registration Method Using IP and Its Application to Ultrasound Image Registration, IPSJ Transactions on Computer Vision and Applications, pp.209-219, 2009. ,
DOI : 10.2197/ipsjtcva.1.209
The Richer Representation the Better Registration, IEEE Transactions on Image Processing, vol.22, issue.12, pp.5036-5049, 2013. ,
DOI : 10.1109/TIP.2013.2281427
URL : https://hal.archives-ouvertes.fr/hal-00916505
A theory of multiscale, curvature-based shape representation for planar curves, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.14, issue.8, pp.789-805, 1992. ,
DOI : 10.1109/34.149591
Combining implicit polynomials and geometric features for hand recognition, Pattern Recognition Letters, vol.24, issue.13, pp.2145-2152, 2003. ,
DOI : 10.1016/S0167-8655(03)00087-4
3D Model Segmentation and Representation with Implicit Polynomials, IEICE Transactions on Information and Systems, vol.91, issue.4, pp.1149-1158, 2008. ,
DOI : 10.1093/ietisy/e91-d.4.1149
Shape transformation using variational implicit functions, 1999. ,
The 3L algorithm for fitting implicit polynomial curves and surfaces to data, AIM@SHAPE, Digital Shape Work- Bench, pp.298-313, 2000. ,
DOI : 10.1109/34.841760
Reconstruction and representation of 3D objects with radial basis functions, Proceedings of the 28th annual conference on Computer graphics and interactive techniques , SIGGRAPH '01, pp.67-76, 2001. ,
DOI : 10.1145/383259.383266
Multi-level partition of unity implicits, ACM Transactions on Graphics, vol.22, issue.3, pp.463-470, 2003. ,
DOI : 10.1145/882262.882293
Fitting globally stabilized algebraic surfaces to range data, Tenth IEEE International Conference on Computer Vision (ICCV'05) Volume 1, pp.1083-1088, 2005. ,
DOI : 10.1109/ICCV.2005.101
Reconstructing surfaces by volumetric regularization using radial basis functions, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.24, issue.10, pp.1358-1371, 2002. ,
DOI : 10.1109/TPAMI.2002.1039207
Interpolating implicit surfaces from scattered surface data using compactly supported radial basis functions, Shape Modeling International, pp.89-98, 2001. ,
Implicit B-spline fitting using the 3L algorithm, 2011 18th IEEE International Conference on Image Processing, pp.893-896, 2011. ,
DOI : 10.1109/ICIP.2011.6116702
Least-squares fitting of algebraic spline surfaces, Advances in Computational Mathematics, vol.17, issue.1/2, pp.135-152, 2002. ,
DOI : 10.1023/A:1015200504295
Gauss-newton-type technique for robustly fitting implicit defined curves and surfaces to unorganized data points, IEEE International Conference on Shape Modelling and Application, pp.121-130, 2008. ,
Fitting unorganized point clouds with active implicit B-spline curves, The Visual Computer, vol.21, issue.8-10, pp.831-839, 2005. ,
DOI : 10.1007/s00371-005-0340-0
3. Orthogonal Distance Fitting of Implicit Curves and Surfaces, IEEE Trans. on Pattern Analysis and Machine Intelligence, vol.24, issue.5, pp.620-638, 2002. ,
DOI : 10.1007/978-3-540-28627-1_3
URL : https://hal.archives-ouvertes.fr/hal-00273956
Estimation of planar curves, surfaces, and nonplanar space curves defined by implicit equations with applications to edge and range image segmentation, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.13, issue.11, pp.1115-1138, 1991. ,
DOI : 10.1109/34.103273
Improving the stability of algebraic curves for applications, IEEE Transactions on Image Processing, vol.9, issue.3, pp.405-416, 2000. ,
DOI : 10.1109/83.826778
Stable fitting of 2D curves and 3D surfaces by implicit polynomials, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.26, issue.10, pp.1283-1294, 2004. ,
DOI : 10.1109/TPAMI.2004.91
Point set surfaces, Proceedings Visualization, 2001. VIS '01., pp.21-28, 2001. ,
DOI : 10.1109/VISUAL.2001.964489
Regularized implicit surface reconstruction from points and normals, Journal of the Brazilian Computer Society, vol.21, issue.1, pp.7-16, 2007. ,
DOI : 10.1007/BF03194253
Smoothing of Partition of Unity Implicit Surfaces for Noise Robust Surface Reconstruction, Computer Graphics Forum, vol.22, issue.3, pp.1339-1348, 2009. ,
DOI : 10.1111/j.1467-8659.2009.01511.x
Symmetry-Based Indexing of Image Databases, Journal of Visual Communication and Image Representation, vol.9, issue.4, pp.366-380, 1998. ,
DOI : 10.1006/jvci.1998.0396
Articulated mesh animation from multi-view silhouettes, ACM Trans. on Graphics, vol.27, issue.3, 2008. ,
Level set surface editing operators, pp.330-338, 2002. ,
Having experienced two years of lecturing in Computer Science, he joined the Computer Vision Center in Barcelona, Spain, where he received the Ph After holding a research position in ICVL Lab at Imperial College London, U.K., he joined Morpheo team at INRIA Grenoble. His current research interests include 3D Computer Vision and Computer Graphics, including shape modeling, surface reconstruction, deformation modeling, object registrations well as machine learning techniques for 3D pose estimation, 2006. ,
after holding research positions in France, the UK, and Greece, he joined the Computer Vision Center, where he is currently a senior researcher. He is a member of the Advanced Driver Assistance Systems Group. His research interests span a broad spectrum within the 2D and 3D image processing. His current research focuses on stereoimage processing and analysis, 3D modeling, and dense optical flow estimation, 1995 and the Ph.D. degree in industrial engineering from the Polytechnic University of Catalonia, 1999. ,
