A runtime approach to dynamic resource allocation for sparse direct solvers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
—To face the advent of multicore processors and the ever increasing complexity of hardware architectures, pro-gramming models based on DAG-of-tasks parallelism regained popularity in the high performance, scientific computing com-munity. In this context, enabling HPC applications to perform efficiently when dealing with graphs of parallel tasks that could potentially run simultaneously is a great challenge. Even if a uniform runtime system is used underneath, scheduling multiple parallel tasks over the same set of hardware resources introduces many issues, such as undesirable cache flushes or memory bus contention. In this paper, we show how runtime system-based scheduling contexts can be used to dynamically enforce locality of parallel tasks on multicore machines. We extend an existing generic sparse direct solver to use our mechanism and introduce a new decomposition method based on proportional mapping that is used to build the scheduling contexts. We propose a runtime-level dynamic context management policy to cope with the very irregular behavior of the application. A detailed performance analysis shows significant performance improvements of the solver over various multicore hardware.
AHugo.pdf (531.01 Ko) Télécharger le fichier
hal-01101054 , version 1 (09-01-2015)
A.-E Hugo, A Guermouche, P.-A Wacrenier, R Namyst. A runtime approach to dynamic resource allocation for sparse direct solvers. 43rd International Conference on Parallel Processing, Sep 2014, Minneapolis, United States. ⟨10.1109/ICPP.2014.57⟩. ⟨hal-01101054⟩
127 Consultations
213 Téléchargements
